Part number request
smonroe111
Stephen
Dallas
Chevrolet Tahoe
I just removed a TwistedShifters shifter that I put on my 7MT 5 months ago and when I did the adapter did not come off and therefore I can’t get to the factory screw/bolt that goes on top. Any help? TIA!!! @flip
RagnarKon
Ford Bronco, Escape, Focus
Wait so what do you need?
The factory knob?? Or the cover for the factory knob?? Or the whole assembly??
Lowcountry Bronco
William
South Carolina Lowcountry
The adapter has a little set screw on the side that you'll have to loosen for it to pop off. Did you keep the Allen wrench they shipped with or the directions, I can scan mine if you need them.
smonroe111
smonroe111
Stephen
Dallas
Chevrolet Tahoe
I am looking for the screw size that is under the plastic top on the original shifter knob.
I changed out the factory knob with a twisted Shifterz knob that reuses the factory screw and an adapter. My factory screw is now stuck between the twisted shifterz knob and the adapter they provide as the little set-screw sheered off when I removed the knob. I probably used too much loc-tite 5 months ago when I installed it.
I’m trying to install a new knob.
Lowcountry Bronco
William
I have the TS knob and adapter too, trying to figure out what you're talking about. Did you get the knob off or is that's what is stuck?
RagnarKon
AH... I think I figured it out.
The TS knob is stuck on the adapter. He was able to get the knob with the adapter off, by shearing the set screw that held the adapter in a specific position, but he can't get the factory retaining screw since the knob is still physically attached to the adapter. Don't have the TS knobs myself so not sure if that's even possible or makes sense, but if that's not what is happening I am very confused.
Anyway... I think he is looking for the following (red arrow):
Ford Bronco Part number request 1696730394635
From what I can see, that screw is only available within the complete shifter assembly (MB3Z-7210-P). Doesn't look like you can get JUST that screw, but I'm not on a machine that has full access to the parts system/service manual right now, so could be wrong.
To be honest... hardware store will be most cost effective anyway. If I recall correctly it has an M3 hex head on it, which probably means it's an M5 x 0.8 flanged button-head screw. Someone can double check me if they wish. But I can get that at my local hardware store for around 25¢... so even if I'm wrong not that big of an investment.
smonroe111
smonroe111
Stephen
Dallas
Chevrolet Tahoe
You got it!!! It was hard to describe. 😂 I found a screw in my screw pile and was able to attached the new TS knob. Thanks for the effort guys! I put significantly less loc-tite on this one. 😉
