Outerbanks Rim/Tire Compatability
BroncoPeder
Peder
brotennn
2021 Bronco Outerbanks
I have a 2021 Outerbanks (not Sport) and I’m looking to upgrade my tire/wheel package. Does anyone know what options I have to increase the rim/wheel size without having to do a lift kit OR worrying about the increased wheel doing damage to the transmission/steering/wheel well tub? I am a newbie to this. Primarily looking to upgrade the off-road look and gain better winter/snow traction. Thank you.
I currently have 255 70/R18
Can I increase to 285 70/R17 rim/wheel set?
[DELETED MEMBER 27901]
275/70 is the most you can do without lift or rub. Plenty of threads on OBX tire swaps. You made a good decision, it really transforms the look overnight.
Beachin 74
Delaware
56F100
john
Venice, FL
56 Ford F100 with 30K original miles
285/70/17 ARE THE SAME HEIGHT AS THE OB 18" STOCK WHEELS/TIRES. THERE SHOULD BE NO PROBLEM WITH 285/70/17. WHY DO YOU SAY 275'S ARE THE BIGGEST?
indio22
Chicagoland, USA
Some people are even doing 315/70R17 (34.4") on stock +55mm offset wheels. Granted they might have some fender rub at full compression off-road, or some mild sway bar rub at full lock. But given how many people hardly (if ever) off-road in these vehicles, probably those tires are fine as well for most uses, at least in terms of fitting.
dbattle
Northern VA
2011 Toyota Prius
Like Indio22 said people are going as big as 315/70/17. That's my current plan when the Bronco arrives. (EDIT: if you do this you'll have to remove the crash bars to avoid rubbing)
I created a spreadsheet awhile ago showing what other OBX owners have done. Hopefully it's helpful.
https://tinyurl.com/OBXBroncoWheels
My mistake, I thought you wanted to keep the OEM wheel. If you replace the wheels too there's a lot more options!
56F100
john
Venice, FL
I am going to change to Analog HD white wheels for that Heritage look. I was hoping to put 285/70/17's on them. They appear to be the same height as my 18" wheels/tires.
