Our Build... So far
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
A little photo shoot of the build process. I still have a Baja Designs 8x XL Linkable Roof Mounted kit to go on, 37" Tires on 12x8.5 wheels, a 3" front/2" rear level/lift kit as well as some Camburg UCAs.
Build should be complete in about 2-3 weeks. But here is the progress so far.
Ohh and graphics. This is our demo truck so we're having graphics done on the side/hood for our shop.
Ford Bronco Our Build... So far Bronco 1 (Small)
Ford Bronco Our Build... So far Bronco 2 (Small)
Ford Bronco Our Build... So far Bronco 3 (Small)
Ford Bronco Our Build... So far Bronco 4 (Small)
Ford Bronco Our Build... So far Bronco 5 (Small)
Ford Bronco Our Build... So far Bronco 6 (Small)
Ford Bronco Our Build... So far Bronco 7 (Small)
MorgansRun
Virginia Beach, VA
BMW 330e
Have you run out of aux switches yet? ;)
De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
Great pics! The new tires and wheels will totally change the look. Anxious to see what you picked!
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
don’t have any :(
Bought truck off lot as is so I didn’t order the upfitter panel - I’m running a cheap auxbeam switch panel - works great
Ford Bronco Our Build... So far 00AB2760-36E9-4823-B0EF-86A24F1E18F8
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I can’t wait for the tires and wheels - I’m not a fan of the stock ones
I went with Nitto Ridge Grapplers I’m 37x13.50 and VR Forged D14 wheels in 17x8.5 in a matte black finish
j_marinelli
Spring Branch, TX.
Look forward to see the picture with the wheels and tires! What lift will y'all be running (if any)?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
FordBroncoLifts.com 3” front/2” rear level lift
De Brus
De Brus
Washington state
Sweet, I dig ‘em! I wasn’t familiar with that wheel so I looked it up. For those who also don’t know, here’s what they look like.
Ford Bronco Our Build... So far Ford-Bronco_Front-1024x576
Ford Bronco Our Build... So far Ford-Bronco_Back-1024x576
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
shimmy825
James
Los Angeles
2017 Mazda CX-5
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
If i put 35's on here i'm assuming these would fit a sasquatch package with no needed adjustments, correct?
Sasquatch already has 35s
shimmy825
James
Los Angeles
2017 Mazda CX-5
i guess it was a dumb question - i just meant i can switch out the wheels no problem right? with no other adjustments needing to be made?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Ohh yeah, you shouldn't have any issues at all if you went with new wheels and kept the same tires.
