- David
- May 18, 2024
- 4
- 54
- 136
- Connecticut
- 2023 Bronco Black Diamond
- Black Diamond
Anyone else having issues after the recent software update?
2023 Black Diamond
Against my better judgement, I let an Over The Air software update happen, now electrical gremlins have reared their ugly heads. Per the Ford App, the update was to correct an issue with the windows, which I did not have.
Daytime Running Lights now come on when the Bronco is locked, unlocked, or ignition is started. DRL’s are deactivated in the systems menu. DRL’s will remain on when Bronco is turned off, and will remain on for an extended period of time. Not sure if the BCM is cutting power to them. I have the lamp delay set to off.
Highbeams are inoperable. The indicator in the dash lights up when I activate the highbeams, but the lights do not turn on.
Left turn signal indicator and noise are rapid flashing/clicking, but the actual lights are operating normally. Right turn signal operates normally, and both in-dash indicators flash/click at normal rate when hazard button is activated.
I am away from home on vacation, so I don’t have access to my ForScan laptop, or code reader. Have scheduled an appointment at dealer for next Thursday. Super frustrated right now.
2023 Black Diamond
