Order Code - what's the significance?
Illwoods
Jeep Wrangler
The dealer I ordered with sent me what I believe is called the DORA?? There is an order code # on there and I was just wondering if this number has any significance regarding the build.
Thanks
smahones
Shane
Denver, CO
Ford Expedition
Lots of threads on this…it’s a priority code you are referring to I believe. 10-19 are all the same for Bronco’s - it means your dealer is telling Ford to build it. If your code is 99 it means you are not considered buildabke by your dealer and it is on hold.
Collinabc123
Collin
Hummer h3
No, but the priority code matters
Illwoods
Illwoods
Jeep Wrangler
I am priority code 19; there is also an order code.
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
I believe he is asking about the sales code or actual order code not the priority code..........
BlueBronco
DFW
Order code does not have any significance. And neither does the sales code.
WildernessMan
Joel
Arkansas
Ford F-150
Thanks
Priority 10-19 codes is what the dealer gives your order when your order is complete and approved by you. Until this happens your build stays in a Priority Code 99 which Ford Motors will see as ā€˜not ready to build’. Now if your dealer gives you a Priority Code 10, Ford will see this as the highest priority over orders your dealer may code with a ā€˜Priority Code 11 thru 19’. Now I’m not sure where reservations intertwine with this formula but if everything was normal and supply wasn’t a issue, Code 10 would be before Code 11-19.
Broncotrax
NORCO
He's clearly asking about the order code..........not priority code.
