ORACLE Lighting: OCULUS BI-LED Headlights for Bronco
ORACLE Terry
Terry
New Orleans, LA
Bronco, RAM TRX, Gladiator, Wrangler JL,
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco ORACLE_Lighting_Bronco_LV_Area
Take a look at the Oculus™ Bi-LED Headlamp system for the 2021+ FORD Bronco by ORACLE Lighting. Featuring a unique modular design, easy plug-and-play installation, and advanced LED projection with 5,200 Lumens of high-quality illumination for enhanced driver visibility in all weather conditions. The Oculus headlight is compatible with both the standard and signature Bronco lighting models.
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco 1668800503461-png
Features:
Precision LED lighting projector for optimum light distribution and beam angle. Installs using original mounting hardware and headlight wiring is Plug & Play into the factory connector without additional relays or harnesses. Halo is available in White, Amber LED, or Switchback Style (meaning white and amber) and features over 200 bright LEDs for a vivid lighting impact.
Benefits:
These all-new headlamps provide enhanced driver visibility with increased and focused LED light output. This complete headlight replacement features a high-precision sharp cut-off line which reduces glare and prevents blinding oncoming traffic even when installed on lifted Broncos. Package includes tool for easy beam angle adjustability.
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco oracle_oculus_rendering2_1024x1024-png
Modular Design:
The new modular design allows separate components (turn signal, marker lights, and mounting tabs) to be installed independently. This modular design provides smaller packaging size for lower shipping costs for the end user and prevents possible damage from shipping on these components. The modular design also allows for these individual components to be replaced or upgraded down the road when future options are available.
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco 2022-08-01_at_3-31-07_pm_1024x1024-png
Reliability:
It is undeniably important to implement proper thermal management tools for high-performance LEDs to operate with reliability in various environments. Oculus utilizes both active and passive cooling methods to sustain low LED temperatures. Remote mounted heat sinks and an internal cooling fan work in conjunction to insure proper temperature control and longevity of the LEDs.
Safety:
Light focus is very important for not only driver safety but others on the road who can potentially have their vision obstructed by glare. This is especially significant on lifted vehicles where the light source is raised and, in a position, to interfere with the field of vision of other drivers. These new Oculus headlights feature a very sharp cut-off line and focus light with precision specifically to avoid such issues.
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco main_amber_oculus_amber_light_bar_1024x1024-jpg
Product Specifications:
- Headlight Wattage: 36W Each
- Total Lumens: 5200LM
- Headlight Color Temp: 5500K (Pure White)
- Halo Color: Optional White or Amber LED or Amber/White Switchback
- Certification: DOT SAE 5839-504 HL VOR 19
- Patented Design: USPTO Patent D 877,404
- Designed and Developed in the USA
- Warranty: 2 Years
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
Tell me more about Switchback style. How/when does it switch between amber and white?
I.Vegabond
Brittany
Nevada
instagram.com
2024 Bronco Badlands
These are definitely one of my favorite lights I've add to Vega. If you are looking for something to help you standout - these are definitely it!
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco IMG_5615
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco IMG_4910
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
Our precision BI-LED Oculus projector headlights deliver optimum light distribution with a sharp, controlled beam angle. ✅ Installs seamlessly using your original mounting hardware—no extra relays or harnesses needed! Just Plug & Playdirectly into your factory connector for an effortless upgrade.
🔥 Plus, the Halo DRL packs over 200 bright white LEDs, creating a bold, eye-catching look on the road. Ready to step up your lighting game? Let’s talk!
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco ORACLE_Lighting_Bronco_Lights_on
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
OracleLights
New Orleans, LA
www.oraclelights.com
Looks that intimidate. Lights that dominate. 🔥
Offered in:
🔵 ColorSHIFT: RGB technology that lets you change your light color to any shade with the push of a button—perfect for show mode and stand-out style
⚪ White: Clean, bright white light for maximum visibility
↔ Switchback : Dual-function LEDs that switch between white (DRL) and amber (turn signal) for added safety and sleek styling.
🔥 Heated Lens: Built-in heating element that prevents fogging, frost, or ice buildup—ideal for cold conditions.
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco 54487782765_188bb849ef_k
DBGBronco
Justin
Kamuela
24 BDSAS
Features:
Benefits:
Modular Design:
Reliability:
Safety:
- Warranty: 2 Years
So the switchback just goes from white halo to amber halo blinker? So if all you want is amber anyway then switchback isn’t for me. It doesn’t switch from white halo to amber halo as I choose.
In the DRL setting, what lights are on in the Oculus? Any issues with the auto highbeam functioning?
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Correct, switchback will be white in DRL mode and Amber only for turn signal. So if you are looking for Amber DRL select our Amber option instead of the Switchback.
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco Oracle-Lighting-SEMA-EVENT-PHOTOS-143_798x798
No issues with the high beam functioning, our lights were designed with LIN-BUS communication so the high beam functions just like factory :)
Iceman62
Tim
Omaha, NE
2024 Bronco / Sasquatch
My kit must've been collected/packed/shipped on Friday @ 4:59, before 5:00 Happy Hour. >.<
Everything from missing parts, no cable labels, cheap pieces (e.g. broken fuse tap) and having to pay shipping to get the needed parts. Responses to my messages have gone silent (ghosting)...sad when a person $pend$ a hefty sum for the parts ($1500 invested in these headlights & taillights).
Anyone who buys these lights definitely needs to scrutinize the contents and instructions to make sure you don't have same problems as my experience. Note: Still fighting to get the cabling figured out w/o labels. :(
OracleLights
New Orleans, LA
Hey there — thank you for sharing your experience. That’s definitely not the standard ORACLE Lighting aims to deliver, especially on a premium-level investment like that.
You’re absolutely right that every customer deserves a well-packed, clearly labeled kit with quality components and responsive support. We have provided the materials needed to make the kit complete — sometimes things fall through the cracks, but we really try make it right once we're aware.
Iceman62
Tim
Omaha, NE
Yes you provided the missing parts, but I had to pay shipping fees for the BC2 controller kit & purchase a replacement fuse tap as the one you sent literally crumbled apart when I simply inserted the Micro fuses. Also, still don't have the halo's & demon eyes functioning.
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Really sorry to hear that, we don't make the fuse taps we purchase these from the local auto parts supplier and include them in the box to make the customer installation process easier.
If you need help troubleshooting the Halos please let us know!
