Oracle Grill Light install - issue with Bluetooth afterwards
jclark
Jeanette
Mid-Michigan
So, got the Oracle lights installed, opted to have a shop connect to electrical. The ask was to have on when the RDL (halo) lights were on.
First attempt, spliced into parking lights behind the headlight wiring harness (pin 9). Worked as wired, not as desired.
Second attempt, spliced into connection 7, in the headlight wiring harness. Didn't work as desired.
Third attempt, wired to fuse box, always on when ignition is on. I can live with that.
BUT - now, bluetooth won't work. As in, I find it in the menu options, it's off, and can't turn it on.
Any ideas? The shop isn't exactly convenient and I'm hoping to find an option that doesn't involve taking time off work and another 30 mile drive one way....
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
None of those headlight splices would affect Bluetooth. It’s a coincidence and unrelated.
jclark
jclark
Jeanette
Mid-Michigan
After a consult with the dealer, they suggested the following troubleshooting -
- reset Sync
- disconnect battery
And if those didn't resolve it, swing by for a system reset, and if that doesn't resolve it, a more involved appointment to troubleshoot the module.
BUT... when I went out to the vehicle to do the Sync reset, the issue had resolved itself. Go figure.
Note that I had turned off and on the car multiple times yesterday when experiencing the issue, as well as had confirmed I was on the current update.
