One-Wheel-Drive on road concerns
Used2jeep
Massachuvian
2007 Crown Vic P71
Used2jeep
Massachuvian
2007 Crown Vic P71
To honestly answer the OP’s question:
4A is just the ability for the Bronco to stay in 2H and “instantaneously” transfer torque to the front wheels by engaging 4H when slip is detected (without you having to reach down and engage 4H)... all while allowing some slippage between axles thanks to a clutch pack. This means you can leave it in 4H on otherwise high traction surfaces without fear of drivetrain binding.
What you’re describing in the Explorer is the symptoms of an open differential, which all Bronco’s have. In an open diff torque follows the path of least resistance, so if one will is free to spin, the motor will just spin that one wheel.
What *should* happen (in modern cars including the Bronco) is the vehicle will apply brake force to the wheel that’s spinning, effectively transferring torque back to the opposite wheel on the same axle. This has the effect of mimicking a limited slip differential. (If the effort to spin the slipping wheel is greater than to turn the wheel that’s propelling the vehicle, you’ll start moving again from the wheel with the traction)
The down side is you’re technically losing some power to heat on the side that’s being braked... but from the driver’s seat you shouldn’t be left stranded, and assuming it’s a temporary slippery patch, you’ll be right back on your way without drama.
When the vehicle starts to cut engine power all together, that’s when things are getting really complicated. More complicated than my whiskey brain can address right now.
DVR binging "Moonshiners"?
Wizard1183
Lafayette
2014 Sierra/ 2010 Camaro 2SS
I can see why Badlands is so popular. I’m tempted, but feel like the lighter/less-expensive Bender (with bronze Method rims) is what I’ll stick with.
Yea. Ticks me off they won’t allow me to get mid pack on lower tier with 7spd manual. I could live with way it was but they force you to bump to badlands to get most of what you want. I find it ridiculous I have to pay $8-10k more for a few options that should cost me no more than $3k tops but have to spend $5-7k more just to get what I want 😡
packages...always packages...
well Ford, I got your package swinging🤣
HotdogThud
mk6 gti, '21 MoarDoor
I’m going to have a problem forgetting that it’s a truck. I’ll have a GT500 to fall back on.
You might want to steer clear of your Local Cars & Coffee events. they don't end well for drivers like you in mustangs.
Mac n Nevada
Reno, Nv.
2007 Toyota FJ Cruiser/2019 Jeep GC Trailhawk
If you mean that bag of cash you are willing to hand over, I am sure they will accept your “package”
Used2jeep
Massachuvian
2007 Crown Vic P71
To quote a commercial "Nice package".
Wizard1183
Lafayette
Im curious if there's a dealer who can install a mid package in Black Diamond while keeping 7spd manual? If so? I'll save a bundle
