Off road
Utahjazzman
BJ
Ram 1500
I finally put the bronco I in different GOAT modes but now it’s stuck in off road mode.
Anyone know how to get it out and back to normal mode?
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
When you turn off the engine and turn it back on it will ask if you want to stay in what every mode you were in before. If you dont hit ok it automatically goes back to normal
If that doesn't work, i would try a battery reset and if that doesnt work, dealer time sorry to say....
Bronc-Itus
Nick
Orlando Fl
‘18 F250, ‘88 4Runner(sold)
Did you by chance shift to neutral? Is it still in 4 low from rock crawl? Try going back to neutral to allow transfer case to shift.
kodiakisland
Arkansas
There are several modes for off road, but not an Off Road mode. What exactly do you mean?
iamchewby
Chewby
Are you talking about the little window to the right of the instrument cluster? I'm assuming because that's the only thing that would say "Off Road", if it is that, use the left arrow on your steering wheel, then use the up arrow to select "My View"
Utahjazzman
BJ
Ram 1500
Thanks for all the responses.
It wasn’t stuck in off road mode. I thought it was because the screen said so ( I have now learned different) but I also get an error now that says pre collision warning and hill assist control have been disabled… it pops up every time I start it.
Any ideas?
Jess
EPT
BRONCO
Any ideas?
I have the same issue. Curious on what other's experiences.
Pseudoko
Vince
Chino, CA
My 2 Feet
Pop it into neutral , turn change to 2H… turn off lockers if they’re on. On your steering wheel just go through the menu to select whatever you feel like being displayed like Trip 1. Hope that helps.
