New Jersey Off Grid Solar Setup
llocchet
Louis
NJ
2022 Ford Bronco
I purchased a 2022 Bronco last week and this off grid solar setup was in the rear cargo compartment. As you can see in the pictures everything was built professionally and the install was performed with great detailed. I have pictures to help support the install if needed. Attached are the wires that run to the battery compartment, wires that run to the rear with a 12 Volt supply, and the wires that tie into the solar panels. I do not have the panels. I'm asking $550 obo. Any questions give me a call: Six 09- 306- Four Nine Zero Nine. I started a thread where others on this forum provided info about the setup:
https://www.bronco6g.com/forum/thre...e-solar-wiring-need-help.133923/#post-2822185
Lou
Ford Bronco Off Grid Solar Setup 802535892
Ford Bronco Off Grid Solar Setup 20260605_164338
Ford Bronco Off Grid Solar Setup 20260606_115015
Ford Bronco Off Grid Solar Setup 20260605_165217
