OEM Bash/Skid Plate Part Numbers?
MNBigfoot
MN
That’s great to hear. Do you know if all hardware such as bolts are included?
Yes, all bolt are included. I got mine through Ford Accessories with a 25% off code (15-20% are real common), used my Ford points and shipped to a relatively close dealer for free (not all dealers offer this/ the ones that do are listed). Sidenote, Ford Accessories is not the most well ran machine by any means, although I got 3 items from them without any issues.
mattjopete
Matt
St. Louis
2025 Azure Gray Badlands, 2015 Jeep Grand Cherokee Limited
How hard was the install? Are there good instructions included?
MNBigfoot
MN
3 of them could be installed in 5 minutes by an 8 year old. Some pretty good youtube videos on all of them. The gas tank helps to have a second set of hands and some cheap rachet straps. I had access to a lift, which made it simple. All simply bolted up with zero troubles. I ran the gas tank down to near empty, for good measure. Also, the crate was much bigger than I expected, bring a truck or a trailer if you have one.
