OBX or Wildtrak?
mpeugeot
Right now I'm leaning towards the 17" +30 RTR Tech 6 wheel in Satin Charcoal. From what I have seen that offset with a 285/70R17 will put the tread just inside the fender with just a little sidewall poke. I don't want the tire slinging water, and dirt on the side of the truck.
The 295/70R17 should be about the same tire poke (2/10ths of an inch or +5mm, really close) which is what I went with on the Satin Charcoal 17x9 +30 RTR tech 6 wheels.
The biggest difference is a 7mm (just under 3/10ths of an inch) increase in ride height over the 285/70R17
https://www.willtheyfit.com/index.p...ct2=70&wheel_size=17&wheel_width=9&offset2=30
mpeugeot
Love the rims!
I am glad that I am not the only one! I got the rims $229 each shipped and the tires were just over $220 each. Mounted and balanced for 4 was right around $2000.
880 + 916 = $1800 (plus 10% discount off both) = $1720 without mounting. I will have to double check my receipts, and remember, I brainfarted and only got 4. LOL, so I still need to fix that error.
TtotheZ
TtotheZ
Tirzah
FL
Yukon, Charger
Sounds like a good deal! Def less than SAS
