OBX 2door HPR build journal
Ft. Worth Rob
Ft. Worth
BMW X7, Bronco OBX
I figured I’d document the changes made to my build in hopes it helps others decide what to do with their Broncos. Feel free to respond/PM if you have questions on the installation of any of these items.
Build: 2.7L, Advanced 4x4, High, Tow, Hot Pepper Red, Roast Interior, Rear Locker
Exterior:
  • License plate mount - BuiltRight Industries
  • Steps/Rock Rails - Zroadz
  • Fender stickers removed
  • Wheels/Tires - Sasquatch wheels with powder coated trim rings and 285/70-17 Falken Wildpeak A/T’s (Oct 2023) replaced with 35x11.5x17 Falken Wildpeak R/T
  • Optimum Opti-Coat Pro ceramic coating
  • (Oct 2023) Eibach Stage 2 coilovers
  • (Aug 2023) Ridergraphix Heritage style upper body crease stripe style C charcoal metallic
Interior
  • Upholstery - Katzkin Black/mahogany, diamond-stitched leather with salsa red stitching and heat/cool option
  • Tint - Xpel Prime XR Plus 70% on windshield, rear side windows, rear window and 30 on door windows
  • Audio - Kicker Key 200.4 powering Focal ASE165 components in front and Focal ACX100 4” in rear pods. Foam speaker baffles for kick panels and pods. Kicker 500.1 with CXARC remote control powering SRQ Customs box with Kicker 8” L7T 4ohm sub wired in parallel to 2 ohm. PlugNPlayKits.com kit 19 plus Kicker 200.4 power adapter plug (powered by battery with 20amp fuse).
  • Bartact paracord grab handles, grab handle storage pouch
  • Shift boot - Redline Goods black leather with red stitching
  • Mats - IAG molded trunk bottom mat, Luxmat front mats
  • Molle grate system rear tailgate - Ford VM2DZ54407B00A
  • Charging - Coolgear Chargeit! Mini 75W Dual Port USB-A & USB-C PD Charger w/PPS & QC4.0 Support connected to battery with Crutchfield 12gauge amplifier wiring kit and 5A fuse with Obvis USB-C 3.0 & USB-A 3.0 male to female waterproof flush mount kit installed in top of dash
  • Device mount - Archetype Racing SLAP/BPM dash accessory mount, Archetype 1” black Mono B.A.L.L.S, RAM RAP-B201U-A composite double arm socket, Bulletpoint universal phone holder
  • Locker security enclosure - Diabolical Inc.
  • Console lock box - Ford VM2DZ-9906202-A
  • Top removal - Rockworkx red anodized thumb screws, TopLiftPros hardtop removal tool
  • Screenprotec matte 12” screen protector
    Ford Bronco OBX 2door HPR build journal 30CD396E-D796-487F-9D3B-30E89EB43177
Ford Bronco OBX 2door HPR build journal 752FBB53-C909-4DFC-9644-2592A19D9E4A
Ford Bronco OBX 2door HPR build journal CE428AB1-D184-46B7-891C-9C1371985247
Ford Bronco OBX 2door HPR build journal C95A78CB-ED37-4470-9765-015A6649F95F
Ford Bronco OBX 2door HPR build journal 65914F87-BA5D-4FA3-9BD9-267E4B581229
Ford Bronco OBX 2door HPR build journal E2823AD1-884A-4C83-9950-E22126FED530
Ford Bronco OBX 2door HPR build journal 97E400D0-22AB-49F0-94A4-D39A955551D4
Ford Bronco OBX 2door HPR build journal 43A789B7-606F-44A6-872E-A2815C14340D
Ford Bronco OBX 2door HPR build journal 4E774FFC-8E21-4505-8FDF-129C81683780
Ford Bronco OBX 2door HPR build journal AF4E6F42-5D19-49A5-9AAE-59C9C890F75B
Ford Bronco OBX 2door HPR build journal 54616DFE-6AFC-441B-8F0B-610FABE834DC
gringoloco
Alabama
2023 2-Door
Tastefully done! Does the SRQ sub require trimming the rear panel?
Ft. Worth Rob
Ft. Worth Rob
Ft. Worth
BMW X7, Bronco OBX
Since I didn’t have the B&O system, I had the cubby hole where the the SRQ grill sits. All I had to do was cut the cubby out from behind where the plastic “rivets” attach it to the back of the panel. No other trimming to the panel.
WILDcardOD
Patrick
SW Michigan
Rav4, Bronco on the way
Exterior:
Interior
Do you feel like the rockworkx red is a good enough match with the hot pepper red? Trying to decide between red and black
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
Exterior:
Interior
Great looking 2-Door!
Love the seats.
Iamthedan1989
Dan
22' Bronco Base
How did you manage to take off the shifter boot to replace it? The sides all come off easily but I get scared I guess at the critical part.
Ft. Worth Rob
Ft. Worth Rob
Ft. Worth
BMW X7, Bronco OBX
From recall so hopefully I’ve fully described it. The boot is glued to a plastic rectangular “ring” at the bottom where it meets the console. I put some painters tape on the plastic console and inserted a plastic pry tool between it and the boot but some have reported they just pushed their fingers into the boot and pulled up on the ring to release it. From there, pull the boot up over the shifter to expose a screw facing the front that allows you to pull the boot and gear shift knob off. You’ll see then how the top of the boot attaches. After peeling the bottom of the boot off the ring, I used upholstery glue and some plastic spring-loaded clamps to hold the boot to the ring until it dried.
Ft. Worth Rob
Ft. Worth Rob
Ft. Worth
BMW X7, Bronco OBX
Added some Eibach Stage 2 coilovers and switched tires to 35x11.5x17 Falken Wildpeak R/T. Also added Ridergraphix Heritage style upper body crease stripe style C charcoal metallic
Ford Bronco OBX 2door HPR build journal 56604E21-24C3-4BBB-8018-6DC8CBD89481
rguest3
Raymond
Another great looking 2-Door! Nice job.
