NOW SHIPPING | Amp Research Powerstep Running Boards
TXBrian
Dallas
2022 Bronco
Y’all doing any Bronco6G coupons or discounts ?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
joeramirez
New Mexico
Ram Truck
Purchased 2 of these from Adam and he is a pleasure to deal with. Get them while they are still available. Mine are shipping tomorrow.
jh3113
Jake
Phoenix
Subaru Outback
Rock-Slide Engineering
Had the RSE's on for over a year now and never had a problem with them draining the battery. I routinely leave it On and go on long trips also, never had an issue.
Raptor911
Raptor911
Broadlands, VA
There is a post here about 2 owners that had their battery go dead after installing these. And now I can't find that thread.
And it's good to hear that you don't have any issues.
Ksjrb03
Tx
F250
There were more than 2 people claiming the RSE steps drained their batteries dead. Never saw the resolution other than they unplugged them.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
https://www.4x4truckleds.com/amp-re...ng-boards-for-2021-ford-bronco-4-door-models/
AMP Research invented the PowerStep™, the automatic, electric-powered running board that instantly extends when you open your door, and retracts out of sight when the doors close for improved ground clearance, aerodynamics and appearance. Its sleek design, all-weather performance and legendary reliability set the industry standard. PowerStep™ has die-cast aluminum alloy components and precision stainless steel pivot pins for rock-solid stability. The original PowerStep™ is American designed and engineered.
  • Automatically deploys and retracts to make getting in and out of your vehicle safer and easier
  • Step anodized and PTFE coated military spec finish that resist corrosion and wear and tear
Includes all hardware necessary for installation. Product comes with easy to understand vehicle specific installation instructions. Be sure to read and precisely follow the provided instructions when installing PowerStep™ Power Running Boards.
Ford Bronco NOW SHIPPING | Amp Research Powerstep Running Boards Photo Jan 24 2023, 12 33 35 PM
Ford Bronco NOW SHIPPING | Amp Research Powerstep Running Boards Photo Jan 24 2023, 12 34 25 PM
kahunabob
Bob
Santa Clarita, CA
4runner
I have had the RSE on my Jeep and the AMPs on my Bronco. If you play in the rocks, there is only one choice....RSE. But, RSE do have their issues. Do some research on the RSE (not just here...but on the Jeep forums too) and you will find some threads that discuss the issues.
IMO, the AMP steps are much better (assuming you are not playing on the rocks). The install is pretty doable if you are handy. I recommend you watch the Motoroso install video on youtube for step by step video install. Motoroso video link:
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I mean if you are going rock crawling a LOT of stuff on a truck is going to get damaged, not just steps.
If you're building a rock crawler, these are not for you. you don't want ANY steps down there and you want to raise your truck and also run bead lock wheels.
kahunabob
Bob
Santa Clarita, CA
4runner
The RSE steps double as a rock slider... which is necessary on the West Coast Rocks. For a rock crawler, you will not have any issues as far as durability running the RSE steps/sliders on the rocks. For a rock crawler, you really have only one choice for an automatic steps.
Now, for the other 98% of people...you should run AMP steps if you are going for automatic steps that work great and look good too.
BroncoDave79
Argyle, TX
Audi A6
We're happy to announce that after months and months of back/forth AMP trying to get to the bottom of the powerstep shortage... orders are FINALLY SHIPPING as of today.
If you have an order in with us for the Amp Research Power Running Boards, they'll ship out to this Tuesday at the latest.
Don't have an order in with us? Well what are you waiting for?!?!?! Get that order in and we'll get it shipped to you within the next 24 hours.
These bolt right up to your Bronco using factory mounting points. They include an ODB II plug so there's no crazy wiring to do. (On the Bronco you just have to plug the module in and tap into 2 wires under the dash using the included wire taps, not to difficult at all).
The steps also have 2 lights per side that are included to illuminate the steps a bit.
FREE SHIPPING within the lower 48 US States and if you are local to our Lindenhurst, NY facility we DO OFFER installation services!
We were swapping out our N-Fab side steps this evening right before we closed (photos/video coming tomorrow)
Neat product!!
Measuring from the bottom of the door, how much of a drop does this provide?
Just trying to figure out what the height of the step will be from the ground then from the step into the bronco.
Thanks!
