Noise over big bumps
Darrick
New york
2021 explorer, 2022 bronco. 1999 f250
Has anyone noticed a clunk noise from the front suspension when going over large bumps. I have heard it before but the other day was on a off road trail and was going over alot of nice bumps and holes and road wash outs. It makes the noise as the suspension fully releases like at full droop. I was thinking maybe the end point stops are very hard or something along those lines. I have a big bend 4 door sasquatch. Any thoughts thanks.
kbBronco
Kyle
Carrollton, TX
2021 Ford Bronco, 2019 Honda Rebel 300
I have a 2DR and hear this clunk, but only when going very slow, no bumps.
T Copp
Travis
KC
Bronco, Mercedes GLB
No, since Raptors haven’t been delivered.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there, I'd be happy to look into your Bronco's noise issue on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Starting noticing it recently going over speed bumps in the parking lot at work, and leaving my driveway. Was going to mention it next time I'm in for service.
Murfman
Colorado Springs
2021 WildTrak, Cyber Orange soft top
Mine is more of a moan than clunk. I think it is either the left front shock or the sway bar on my Wildtrak.
Jbou1010
Louisiana
FORD F150
I have it also. sounds as if something needs some lube
BroncoBarn
Illinois
2002 Wrangler
Did anyone get this resolved? I noticed this on our 2022 with 500 miles.
CASM920
Gen 1 Raptor, Bronco Badlands
If you have a Sasquatched Bronco it’s most likely that you are hearing the Bilstein shocks engaging the ESCV which is essentially the internal bump stop. The shock piston engages with the end cup with a noticeable clunk, for me usually on droop as in the downside of a bump/hump.
pmoore00
Phil
2022 Badlands Sasquatch 4d
I am hearing something at low speeds over mild road bumps that sounds very much like an engine “knock” but it’s clearly coming from the suspension, feels like left rear. Is that the sound the ESCV engagement on the Bilsteins might make? Not a moan, or even a bump. More like a hollow knock.
I’d love to correlate the sound I’m hearing to something others are hearing. Also I’d love it understand if it’s normal or an indication of premature wear or a defect. If not, I’ll just turn up the radio.
  • Love
Reactions: 0ne
CASM920
I would say describing it as a hollow knock is accurate. When you hit the bump are you square to it, as in both tires rise and fall together? I ask because if that is the case and only one side “knocks” you may have a shock issue and I would have service look at it. Furthermore, the front would be more likely to engage ESCV due to having less travel than the rear. On my Raptor if a shock was getting down on nitrogen it would begin to clunk and I knew it was time for a rebuild.
pmoore00
Phil
That is a great question. I’m pretty sure I only hear the knock from the left rear even over, say, a speed bump where the front and rear shocks compress pretty uniformly and simultaneously. Sounds like I may actually have an issue. Thanks!
0ne
Nate
CO
Flex
🤘Yes! I think with current service backlogs at dealerships that ignoring it and driving until failure are sound strategies.
Murfman
Colorado Springs
Mine is going in for service Wed. This time taking the Service Manager and suspension expert for a ride......
TheRealLizG
Lizeth
Your dads house
Yes! I’ve also felt the vehicle is handling the road bumps as well as it used to. Example I’m bobbin around more in my seat. Used to feel a lot smoother. So, making a service call manana and also having them look into my window rattles. I notice the undercarriage sounds more on the front end and it can be from pot holes, railroad tracks anything really. I’m at 12,000 miles and really heard it driving off-road uphill. But now I notice it at any little bump. Don’t recall hearing this before. Then again it was colder weather and I had the windows up. Any updates on if you took your bronco in for service and if issue was resolved?? I’m hesitant to go to the dealer I usually go to( not the dealer I purchased from) bc first time I took for a new parts install they didn’t know how to do it and second visit for an oil change appointment they seems too busy to handle the smallest customer service gestures. But it’s the closest dealer to me so we’ll see how they handle that this.
