NEW: Two door Power Tank mount
Status
Not open for further replies.
B34R
Georgia
'04 VW R32, '17 Audi S3, '19 Toyota 4Runner
Very creative! Great use of the open slots. Would you mind if we used your photo on our website?
And thank you for your business!
It's not the best pic but feel free to do so. We also have your tank + mount setup on a 5th gen 4runner. Both great designs to securely mount the tanks. Glad to see the support for us 2 door enthusiasts!
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
I'm running American Adventure Lab Bronco Cargo Floor Multi-Mount – Battery and Compressor Bracket. Went with the 4 lithium battery setup to power my fridge and misc usb items as needed. The Dometic fridge is wired to Dometic DC kit which mounts directly to the Power Tank plate mount. Eventually I'll be relocating the DC kit and fridge once I install a partial rear seat delete.
Thanks! I'll send you a DM with a couple of questions about your setup so I don't hijack this thread any further.
Like you, I installed the PT mount in our '18 4Runner and have been VERY impressed with it, so I've been waiting on this bracket to do the same in our 2 door Bronco. Power Tank is a great option for onboard air and they have been a fantastic vendor to work with.
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
2022 Badlands Sasquatch
We appreciate your business!
@B34R I noticed the flashlight on zoom-in. Cool detail. I wear my olight every day.
heliix
Maryland
2Door OBX Lux Eruption
Can the handle be removed? I have the cargo enclosure that is 22 inches high.
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
Yes but the handle is the main protective device guarding your regulator and valve and removing it voids your regulator warranty. If the Power Tank stays mounted in the vehicle, there is low risk of damage but if you take the Power Tank out to help someone on the trail, it's a good idea to put the handle back on in case the Power Tank gets knocked over. It's two simple bolts with an 8mm allen.
heliix
Maryland
i though that the handle is for protection. how many tires will a pt1 fill 20 to 40 psi 255 70r18 ?
mcinfantry
Lee
Louisiana
Badlands 2 door
10lb tank will do
4 35x12.50 7psi to 30
4 Stock Sasquatch 18-35
4 Stock Sasquatch 15-35
and I have enough to do it agin.
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
The handle's number one function is to protect the regulator and valve. We do not recommend removing it for any reason other than refilling the Power Tank. It can, however, be removed by unscrewing two bolts.
You would get easily 20+ tire fills on that size tire with a 10 lb Power Tank.
heliix
Maryland
I found the charts on the website but it doesn’t list the PT1 power shot.
PTTyler
PTTyler
Tyler
Lodi, CA
powertank.com
20 oz = 1.25 lbs. You can divide the numbers of the 10 lb Power Tank by 8. The Power Shot is only good for one or two emergency tire repairs. Not enough volume to be able to use for primary air up duty.
Johnny Rebel
LA
Finally got the time to mount my bracket this morning. This thing is awesome! Everything went together smoothly and all holes matched up perfectly to the Bronco mounting points.
I bought the 5lb tank package, but decided to install one of my 15lb tanks for now. Since the rear seats on my 2 door stay folded 90% of the time, tank clearance isn’t an issue.
There’s enough room to mount a Camelback MOLLE bottle bag to store the inflator, and also room to install the PowerTank fire extinguisher bracket that I used to mount a Pro Eagle Phoenix DS air jack.
Thanks @PTTyler and crew for making a great product!
Ford Bronco NEW: Two door Power Tank mount IMG_7332
Ford Bronco NEW: Two door Power Tank mount IMG_7335
Status
