You should be fine to add spacers on the rear to get level. You may want to go just a bit higher in the rear to account for passengers & gear. These suspensions are pretty soft so doesn't take a whole lot of weight to make the rear sag.Correct....The shop already installed the level kit. The 1" R.C. leveling kit has 3 spacers that go in the front only. It looks great, but I'd still like to get the rear to the same height (it's currently just under an inch higher in the front). So it actually must have raised the front more than an inch.
Do you think I can safely add another spacer or two in the rear if I order another kit?
