Sold: Texas NEW Pro Comp Coilovers & ADS UCA's - $1850
MatteOBX
2022 Bronco
Front & Rear 2.5" VRST Pro Comp coilovers (spanner wrench included) for 2021 to 2024 Bronco and ADS Tubular HD Front Upper Control Arm Kit.
All parts are brand new, never installed, only removed from box for pics. Selling Bronco and no longer need.
I live between Austin & San Antonio but travel to all major Texas cities often.
Absolutely NO shipping!
Prefer to sell as a package but will entertain offers for coilovers and UCA's separately.
Retail before shipping & tax = $2268
Asking $1850
Pro Comp Coilover Front - PCS52233BX-1
Pro Comp Coilover Rear - PCS52233BX-2
Spanner Wrench
ADS Tubular HD Front Control Arm Kit - 512ADS
Coilovers
For the most challenging terrain the all-new 2.5 PRO-VST SERIES shocks are the PRO's choice. These new shocks are built to endure off-road carnage while providing lasting damping performance. Designed for maximum off-road capability, the 2.5" PRO-VST Monotube Shocks and Coilovers are constructed with a hard-anodized thick wall impact forged body. The robust 2.5" shock body on the PRO-VST allows for maximum damping capacity. The hard-anodizing reduces friction and bore wear inside the shock-body. Featuring 17-4 PH stainless steel precipitation hardened shafts that are chrome plated for maximum corrosion and abrasion resistance. With Vehicle Specific Tuning (VST), Pro Comp PRO-VST shocks are specifically tuned for maximum ride quality on-road and pro performance off-road!
UCA's
Upgrade the front of your 2021-2024 Ford Bronco with our Heavy-Duty Tubular Steel Upper Control Arms. Engineered to correct camber, caster, and accommodate lifts up to 4 inches, these control arms feature acetal copolymer bushings that provide significantly less deflection compared to stock rubber. Durability is king with a 1.250-inch OD x .188-inch wall DOM steel frame and finished with a sleek gloss black powder coat. The included ball joint dust cover, CNC machined from 6061 billet aluminum, is anodized in gold, laser engraved with the ADS logo, and protected with a clear powdercoat for UV resistance. Fully rebuildable and utilizing a standard ball joint with a rubber dust boot, this product also includes Grade 8 hardware, ensuring top-tier performance and longevity for all your off-road adventures.
Features:
  • Corrects camber and caster, accommodating lifts up to 4-inch
  • Acetal copolymer bushings provide less deflection than stock rubber
  • Included ball joint dust cover
  • Fully rebuildable
  • 1.250-inch OD x .188-inch wall DOM steel construction
  • Control arm finished off with gloss black powdercoat
  • Dust cover is CNC machined from 6061 billet aluminum, anodized gold, laser engraved with ADS logo, and clear powdercoat for UV resistance
  • O-ring sealed uniball dust cover
  • Utilizes standard ball joint with rubber dust boot
  • Grade 8 hardware included
Ford Bronco NEW Pro Comp Coilovers & ADS UCA's - $1850 BF Lift
Ford Bronco NEW Pro Comp Coilovers & ADS UCA's - $1850 ADS
Ford Bronco NEW Pro Comp Coilovers & ADS UCA's - $1850 ADS 2
Ford Bronco NEW Pro Comp Coilovers & ADS UCA's - $1850 Pro 1
Ford Bronco NEW Pro Comp Coilovers & ADS UCA's - $1850 pro 2
Ford Bronco NEW Pro Comp Coilovers & ADS UCA's - $1850 pro box
Ford Bronco NEW Pro Comp Coilovers & ADS UCA's - $1850 pro box 2
Ford Bronco NEW Pro Comp Coilovers & ADS UCA's - $1850 Spanner
White Zombie
jim
North Dakota
22 bronco
I looked online and read your post, I'm going to guess that these coilovers do not add any lift or did I miss that some where in any of the information? Yes, I saw the 2.5" but thats the body of the strut.
MatteOBX
2022 Bronco
Yes they add up to 2.5" of lift
MatteOBX
2022 Bronco
Sale Pending
