New leak please: Decoding the 16 'packages'
Carolina Jim
Highlands
2021 Bronco 2-door
Base Standard
Big Bend: Standard, Mid
Black Diamond: Standard, Mid
Badlands: Standard, Mid, High, Lux
Outer Banks: Mid, High, Lux
Wildtrak: Standard, High, Lux
Those are the packages from last weeks leak; presumably a 'first edition' will be offered as well. Understanding the colors, suspension, engines, and tech associated with each would be helpful in navigating the reservation process. And this detail is too granular to include in the 8:00 infomercial we're all looking forward to.
WuNgUn
Ontario Canada
2 door Squatched
Base Standard
Quite likely you'll just be making a place holder with your reservation...
The spec and build will come later, I'm assuming.
North7
North Texas
SUV
Base Standard
Here are the extraction of the Package Names and Codes. I've also attached the info sheets on the Ford F-150 and Ranger. When you look in those you will see similar package numbers, 300A, 301A, 302A, etc. Those correspond to Base, XL, XLT, etc.
Perhaps with someones further comparison you can get and idea of what the Bronco Code numbers may include.
Here is the extraction for the Package names:
First Edition Package
Base Standard Package
Big Bend Standard Package
Big Bend Mid Package
Black Diamond Standard Package
Black Diamond Mid Package
Badlands Standard Package
Badlands Mid Package
Badlands High Package
Badlands Lux Package
Outer Banks Mid Package
Outer Banks High Package
Outer Banks Lux Package
Wildtrak Standard Package
Wildtrak High Package
Wildtrak Lux Package
Sasquatch\u2122 Package
Here is the extraction of the Package Codes:
E5A
E5A-BASE-101A-2-DOOR-4x4
E5A-BID BEND-221A-2-DOOR-4x4
E5A-BIG BEND-222A-2-Door-4x4
E5A-BLACK DIAMOND-321A-2-Door-4x4
E5A-BLACK DIAMOND-322A-2-Door-4x4
E5A-OUTER BANKS-312A-2-Door-4x4
E5A-OUTER BANKS-313A-2-Door-4x4
E5A-OUTER BANKS-314A-2-Door-4X4
E5B
E5B-BASE-101A-4-Door-4x4
E5B-BID BEND-221A-4-DOOR-4x4
E5B-BIG BEND-222A-4-Door-4x4
E5B-BLACK DIAMOND-321A-4-Door-4x4
E5B-BLACK DIAMOND-322A-4-Door-4x4
E5B-OUTER BANKS-312A-4-Door-4x4
E5B-OUTER BANKS-313A-4-DOOR-4X4
E5B-OUTER BANKS-314A-4-Door-4X4
E5C
E5C-BAD LANDS-333A-2-Door-4x4
E5C-BAD LANDS-334A-2-Door-4x4
E5C-BADLANDS-331A-2-DOOR-4X4
E5C-BADLANDS-332A-2-Door-4x4
E5C-WILD TRAK-352A-2-Door-4X4
E5C-WILD TRAK-353A-2-Door-4X4
E5C-WILD TRAK-354A-2-Door-4X4
E5D
E5D-BAD LANDS-333A-4-Door-4x4
E5D-BAD LANDS-334A-4-Door-4x4
E5D-BADLANDS-331A-4-DOOR-4X4
E5D-BADLANDS-332A-4-Door-4x4
E5D-WILD TRAK-352A-4-Door-4X4
E5D-WILD TRAK-353A-4-Door-4X4
E5D-WILD TRAK-354A-4-Door-4X4
E5E
E5E-FIRST EDITION-4-Door-4X4
E5F
E5F-FIRST EDITION-2-Door-4X4
j_marinelli
Spring Branch, TX.
You know this commercial just seems to fit. Bronco rolls up to the trail with jeeps already there. He tries to be respectable but a few of the jeep owners want to mess with the bronco owner. Then kicks in Sasquatch... ?
Carolina Jim
Carolina Jim
Highlands
2021 Bronco 2-door
we are going to get most of what we want
that's what I'm reading on one of the other forum threads....I'd just like to see a 'roadmap':
"a drop down box to select a Bronco or Bronco Sport. By selecting Bronco, another drop down will be 2 or 4 door. Then options and packages will come up. This is the info I got today."
Carolina Jim
Carolina Jim
Highlands
2021 Bronco 2-door
Thanks 7....yours is a logical approach. I just keep seeing 'insiders' say Bronco won't follow the XL/XLT structure - so I'm hopeful of a more freewheeling format
North7
North Texas
SUV
You misunderstood what I was trying to say. You are correct that Bronco will not use the names, XL, XLT, etc. They will have package names such as Big Bend, Wildtrak, Sasquatch, etc. However, the Ford internal code numbers are similar but they simply map to a different package name, here is the Ranger example from the attachment above:
Ranger PACKAGES
â—ŹBed Utility Package (86Q)
●Ford Co-Pilot360™ (67G) – available on XL 101A
●Technology Package (67J) – available on XLT (301A/302A)and Lariat
â—ŹFX4 Off-Road Package (914) NA on XL Base 100A
●STX Appearance Package (76F) – available on XL 101A only
â—ŹTrailer Tow Package (53R)
●XL Chrome Package (76H) – available on XL; 100A Fleetonly
●XL Power Equipment Group (67F) – available on XL (100A)Fleet only
●Chrome Appearance Package (76G) – NA on XLT (300A)and Lariat (500A)
●Sport Appearance Package (76E) – NA on XLT (300A) andLariat (500A)
ChrispyKC was explaining the package numbering and related content in these posts:
Carolina Jim
Carolina Jim
Highlands
2021 Bronco 2-door
I hear'ya. I'm probably a 2-door 101A kinda guy - looking to see if I can get the 2.7 in a lower trim before most of the tech packages kick in.
aabsalon
Alan
Sacramento
Toyota Tacoma
So will a configurator without the prices come up tomorrow?
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
Are we going to have to pick out packages and options for the pre-order? Or will that come later?
odds are starting Tommorrow your just grabbing a “line place holder” like a number at a deli.
Where full ordering with trims colors packages will be later on (fall)
that’s for the bronco.
bronco sport will be the full order deal. With price
