- Gary
- Aug 18, 2024
- 36
- 563
- 464
- Costa Mesa CA
- 2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
- Badlands
At least I have never heard of this issue. I used the lower control arm removal method and took care not to over extend the axle that I have heard is the biggest issue with this approach. I strapped the back of the knuckle to the frame to make sure the axle would not over extend. The strap was not tight but just secure enough keep it from moving out much. The front of the hub was secured with the tie rod so it was not going anywhere.
What I discovered when assembling is some how I got the lower control arm in too far. I had a difficult time getting the control arm back out far enough to get it back into the slots on the frame. I used a jack to lift the control arm and had to little by little pull it out to get it in the slots where the lower control arm fits. I didn't have to use a lot of force to pull out but it was not easy either. Once I got the control arms in the slots it was pretty easy to get the holes aligned to get the bolts in.
Here in my question, is there anything I could have damaged by getting hub too far in on the axle.
Later when I did the other side, I made sure to not push the control arm in and it went back together easily.
