Need Help - Carobotor Cluster Causing High Coolant Temperature?
zezosam
Abdulaziz
saudi
Hi everyone,
I wanted to share my experience and see if anyone has had the same issue.
Vehicle:
  • 2022 Ford Bronco Wildtrak
  • 2.7L EcoBoost
  • Plug-and-play Carobotor digital cluster
For the past few months I have been chasing what looked like an engine overheating problem.
I replaced or checked:
  • Radiator
  • Thermostat
  • Coolant
  • Head gaskets
  • ARP studs
  • Cooling system
  • Various sensors
Nothing completely solved the issue.
Yesterday I reinstalled the original OEM Ford cluster and immediately noticed a huge difference.
Results with the OEM cluster:
  • Coolant temperature stays around 82-89°C
  • No engine safe mode
  • Cooling fans behave normally
  • Vehicle drives normally
When the Carobotor cluster is installed:
  • Coolant temperature rises much faster.
  • Cooling fans become much louder.
  • The vehicle previously entered engine protection/safe mode.
The Carobotor cluster is fully plug-and-play with no wiring modifications.
Has anyone experienced:
  • Incorrect coolant temperature readings?
  • CAN Bus communication issues?
  • High fan speed after installing the Carobotor cluster?
  • Any firmware update that solved the issue?
I’d really appreciate any feedback before reinstalling it again.
Thank you.
maliu
Janet
Hawaii
F250 Godzilla
I’m a nurse. When there is a problem we look at the last thing we did/gave. You changed the cluster, had a problem, threw a bunch of parts at it then discovered the problem was the after market part you put in and you want to try it again?
Interesting that the instrument cluster can send the engine into limp mode... I would have said the cluster is just reading from the incorrect PID for coolant temp, but not if that's actually occuring (not something you can fix on your end)
zezosam
Abdulaziz
saudi
That’s exactly why I’m investigating it. I also assumed the cluster was read-only. But the limp mode and overheating behavior only occurred with the Carobotor installed, and disappeared after removing it. I’m hoping to understand whether it’s a firmware or CAN bus communication issue.
zezosam
Abdulaziz
saudi
šŸ˜‚ Lesson learned: sometimes the last thing you install really is the first thing you should remove.
