Navigation options for Base display screen?
navi
Navi
CA
73 Bronco
What are folks using to get Nav on the base bronco screen besides carplay or Android auto?
Is there any way to use the satellite connection or does it have to be cellular?
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
I added Nav to a friend's 2014 Escape with Forscan. Can you not do that with the base Bronco radio?
XirallicBolts
Xira
Midwest, USA
2016 Flex EcoBoost, 2022 Silverado LT
I'm guessing not. Sync2 stored maps externally on an SD card. Sync3 and Sync4 store them internally. The non-nav Sync3 APIMs simply did not have enough storage for maps and your only option was to physically swap the APIM. I wouldn't be surprised if Sync4 was the same.
Given the Sync 4 APIM still uses the same 54-pin connector as all previous generations (even the base 2008 version without a touchscreen), there's hope an APIM swap is a viable upgrade path.
Looking on eBay, the nav APIM has an additional fark connector for anntnna. Similar to previous upgrade kits, probably have to add your own antenna. It appears there's also a physical difference between "8 inch" and "12 inch" APIMs, with 12" gaining yet another fark connector in the empty spot in these two pictures.
Ford Bronco Navigation options for Base display screen? nav
Ford Bronco Navigation options for Base display screen? nonnav
navi
Navi
CA
73 Bronco
Fark!!
XirallicBolts
Xira
Midwest, USA
So... you don't have a smartphone?
I could write a novel about how much I hate Google Maps on Android Auto. Five of the paragraphs would be CONTINUE STRAIGHT CONTINUE STRAIGHT CONTINUE STRAIGHT because Google thinks I'm going to make a hard right turn off the freeway onto a 200ft dirt road.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Ford Bronco Navigation options for Base display screen? the-office-gps
