Nav in miles?
Function_7
James
'Berta
Just my Bronco
Q for my fellow Canadians, have you noticed your voice instructions and turn by turn directions are in miles since the latest update?
I’ve got all my measurements set to KMs, and the prompts even show up in KMs on the dash, but show up as miles on the big screen. I can’t figure out how to make it right.
Anyone else experiencing the same problem? Anyone figure out a solution?
any advice @Ford Motor Company?
Gilligans_off
Vince
Canada
2022 2 Dr Bronco Badlands Sas/lux
I just noticed this yesterday. Haven't had time to go through the menus but I hope you can change it.
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
I haven't used my Nav since the update but I will try it on the way home today.
Paul Gagnon
Paul
Ok, I am seeing this too. It was showing me miles in the Nav screen and kilometres in the gauge cluster. I switched the units to miles and then back to kilometres and the Nav screen was now showing the correct units. I had to make a ten minute stop on the way home and when I started driving again, the Nav screen was back to miles. I shut the engine off and opened the door a couple of times after that and the Nav screen stayed on kilometres each time. I will try it again tomorrow.
As a side note, when I switch the units to miles, my speedometer still stays in kilometres. It has been doing this for months. I’m pretty sure since the updates in June. Has anyone else noticed this?
@Ford Motor Company
Ford Bronco Nav in miles? A8C720C6-24E7-4FF4-BE19-190412E726DE
Ford Bronco Nav in miles? E3CB6389-713C-49D3-9EE1-248A0CEF88A0
Paul Gagnon
Paul
I tried it again this morning. It reverted back to showing miles in the Nav. It did change back to km after changing the settings but I am sure it will be wrong again next time. It's pretty inconvenient.
Function_7
Function_7
James
'Berta
Just my Bronco
I’ve got an oil change and service booked on Friday, so I’ll see if the dealership has any insight, but I’m not expecting much.
Eddie Bauer
Duncan
Edmonton
'07 Pathfinder
I was having this issue as well. I selected Miles in the settings and drove for a few minutes, then went and switched it back to KM and it seemed to work.. the nav was back to KM. I havent noticed it going back again to Miles as Paul noted, but then again it was just this morning that I noticed and tried to fix.
Paul Gagnon
Paul
Here’s a little video I made on the way to work this morning.
Eddie Bauer
Duncan
Edmonton
'07 Pathfinder
I went out for a drive over lunch and yes, mine continues to revert back to miles. I switched it back to KM, turned the car off, and when I immediately started it back up again it was back to Miles again. Terribly annoying!
I don't think I've ever been able to put my speedo in miles though.. but I've only had it a week lol
Paul Gagnon
Paul
I'm think my speedo switched to miles when I first got it but I could be wrong.
Function_7
Function_7
James
'Berta
Just my Bronco
Paul Gagnon
Paul
Another thing I noticed on the way home today is that the little speed limit reminder in the gauge cluster says kilometres even when the units are set to miles. So that is following the speedometer. @Ford Motor Company really needs to figure this out.
Ford Bronco Nav in miles? 653E7C3C-9083-4EA6-9F4C-5F40BEF3093B
Function_7
Function_7
James
'Berta
Just my Bronco
Anyone get/find an update for this? @Ford Motor Company ?
Had the Bronco in to the dealer for an oil change last week. Dealer said they would look into it by calling the Ford engineers and calling me back when they had a solution. Radio silence so far. @Ford Motor Company do you want my VIN and dealer info so you can help them figure it out??
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Don't bother tagging FoMoCo - Once they learn you're in Canada, they just tell you they can't actually help you. I know this from first hand experience... :rolleyes:
One solution to this issue is to print out maps from MapQuest :ROFLMAO:
