Multi LED Roof Mounted Light Bar
ZROADZOFFICIAL
ZROADZ
Corona
2022 Ford Bronco
Front Roof Multiple LED Pods KIT, Tubular Mounting Bar with White and Amber Pods and Wiring Harness - Part # Z935401-KITAW
Features & Benefits:
  • Front Roof LED Kit
  • Sold as a complete kit
  • Includes:
    • (6) 3 Inch White ZROADZ LED Pod Lights
    • (2) 3 Inch Amber ZROADZ LED Pod Lights
    • mounting brackets
    • custom wiring harness with fusible link, relay, toggle switch
    • all necessary hardware
  • Light Performance:
    • 1712 Lumens
    • 20 Watts
    • 5W LED Chips per pod light
  • Manufactured from heavy guage mild steel and 1.5 inch tubing
  • Easy, bolt-on installation, no drilling required
  • Black - Low Gloss Textured Powder Coat finish
  • Limited 3 Year Warranty Against Material and Workmanship
  • Designed and Manufactured by ZROADZ Off Road Products in Corona, California
  • Also available as bracket only, see part number Z935401 or with white pods Z935401-KIT
Ford Bronco Multi LED Roof Mounted Light Bar small roof mount Untitled-1
Ford Bronco Multi LED Roof Mounted Light Bar Z935401-KIT_opt_3
Ford Bronco Multi LED Roof Mounted Light Bar Z935401-KIT_opt_10
Ford Bronco Multi LED Roof Mounted Light Bar Z935401-KIT_opt_18
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Yeah, this combo light kit is what I think I wanna put on the Wildtrak. Now to figure out how to wire it…and find someone to help lift it in place😂😂😂
