- Adam
- Aug 30, 2021
- 360
- 4,414
- 5,871
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
We are happy to announce we have stock on the new MORRFlate TenSix PSI Pro Portable Air Compressors!
A lot of people have been waiting for this portable air compressor and they are finally here.
This is a portable air compressor designed to work with the MORRFlate Multi-Tire Inflation Hose Kits. Meaning you air up all 4 tires at once. It's not designed to air up one tire at a tie (in fact, the manufacturer DOES NOT recommend doing that). It'll also work with other multi-tire inflation hose kits but the MORRFlate Kits pair perfect with it (which we also stock).
The biggest takeaway with this compressor is that you just set the PSI you want on the compressor and walk away. It does the rest. A great solution for someone who doesn't want to invest in an on-board air solution. The kit includes a carrying case but it DOES NOT include air chucks, because again they expect you to use this WITH The MORRFlat Multi Tire Inflation Kit.
SPECIFICATIONS
MORRFlate TenSix™ PSI Pro™ 12v Portable Compressor
https://www.4x4truckleds.com/morrflate-tensix-psi-pro-12v-portable-compressor/
Don't forget to add one of their multi tire inflation hose kits (the Quad works best for a Bronco)
MORRFlate Quad (4 Tires, Up to 125″ Wheelbase)
https://www.4x4truckleds.com/morrflate-quad-4-tires-up-to-125-wheelbase-1/
SPECIFICATIONS
- Air up a set of 35″ tires from 10 to 40 psi in 6.5min (when combined with a 4 Tire Hose Kit)
- 10.6 CFM dual cylinder compressor at 0 PSI
- 6.5 CFM at 30 psi
- 10-120 psi in Auto Mode
- 1-150 psi in Manual Mode
- 50% duty cycle (20min on, 10min off)
- 12v, 90amps peak, ~50amp running
- 14x7x9″ external dimensions
- 70-75 dB noise level from 1ft distance
- Thicker carrying bag with accessory pockets
- Threaded filter caps so the compressor can be mounted in any direction/orientation
- USA Standard color matched air fitting – “Universal” Coupler (Works with Industrial or Auto fittings 1/4″ plugs)
- 6ft hose off of the compressor
- 6ft electrical cord, terminates in high amperage alligator clips
- WARNING: Compressors get hot! Recommended to wear the included MORRFlate Groovy Gloves while disconnecting air fittings.
- Since the TenSix™ is rated for 10.6 CFM, it is highly recommended to use with a MORRFlate 4 Tire Inflation & Deflation™ Kit to avoid back pressures on the compressor from filling 1 tire at a time.
