Monthly Payment Tool
centra28
Dale
Kansas City, MO
2021 Jeep Gladiator Mojave
I built this tool for myself to use to try and figure out what my monthly payment would be if financed. I tweaked it a little bit after some more info came out. I left all cells unprotected so you can change at will. The formula I am using for calculating the financing is visible in column S.
For myself I wanted to compare monthly payments of what I would want in a Black Diamond trim vs Badland trim, so that is the explanation for the colors and the data left populated in the cells. I left the data in the cells as an example of how to use. Just delete the items in blue or black and customize with your own data. I also listed some of the pricing from the surveys in columns O & P - but not all as I only listed the items for the trims that I was interested in keeping.
Hope this helps you. I'll try to answer questions but I think it is self explanatory. Keep in mind this is just for fun and should not be considered to be exact as I could not possible consider all variables, though I did validate the results against the pricing tool on the ford site.
note, for the finance percent enter the decimal not the % number. so in the examples I left I used 3.5% entered as 0.035. If you wanted to use 5%, as an example, then enter as 0.05. It does not work at 0% so just use a really small decimal (like .000001) to get a decent result.
Lordbam
Biagio
Bmw
This is awesome thanks for sharing!!
centra28
centra28
Dale
Kansas City, MO
If it makes anyone feel any better, my Badlands/Lux package dreams are pretty well crushed.
sprtsmac
AJ
Oregon
2000 F-150 XLT, 2019 Ford Escape
So cool. Thanks for sharing.
Bronco4lyfe85
William
2019 Challenger Scat Pack
Why would that make anyone feel any better?
Bronco4lyfe85
William
Bronco4lyfe85
William
OP. This is awesome!! Thanks a ton, very easy to use and get an idea of what i’m looking at.
ChristopherDobson
Fargo
2021 Ford Bronco Big Bend
By the way, if you ever need to audit payment flows or trace financial records when building or testing custom scripts and tools like this, knowing how to check a transaction ID properly is super helpful for keeping logs accurate.
Nice tool, especially for comparing trims side by side instead of relying on rough estimates. Seeing how different options affect the monthly payment makes it much easier to decide whether the extra features are actually worth the cost.
Since this thread is older, I'd also factor in today's financing rates, taxes, registration, insurance, and dealer fees, as those can have a bigger impact on the monthly payment than they did when this spreadsheet was first posted. It's still a useful way to compare scenarios before talking to a dealer.
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Welcome to B6G. I wouldn't hold out waiting for @centra28 to reply. He was last seen 3 years ago. You did quote his message from nearly 6 years ago.
