Mishimoto Baffled Catch Cans NOW AVAILABLE | Lethal Performance
LethalPerformance
South Florida
www.lethalperformance.com
Ford Bronco Mishimoto Baffled Catch Cans NOW AVAILABLE  |  Lethal Performance BRONCO mishi catch can
Hey All!
Mishimoto has just dropped their all new Baffled Oil Catch Can Kit for 21+ Bronco, both for 2.7L and 2.3L applications after Extensive Testing and Prototypes over the past couple of months.
Mishimoto Baffled Oil Catch Can Kit (2021+ Ford Bronco 2.3L) - MMBCC-BR23-21P
Ford Bronco Mishimoto Baffled Catch Cans NOW AVAILABLE  |  Lethal Performance mmbcc-br23-21p_1
  • Direct fit for 2021+ Ford Bronco with 2.3L EcoBoost​
  • Catch can captures blow-by, preventing it from fouling engine oil​
  • Sturdy 2.7mm-thick steel brackets withstand rough roads and off-road abuse​
  • Includes high-quality, fuel and oil-resistant hoses with pre-installed quick-disconnect fittings to make installation easy​
  • Direct-fit bracket mounts the catch can away from engine vibration​
  • Protects intake valves from power-robbing carbon buildup​
  • Pre-installed factory-style quick-disconnect fittings for clean installation​
  • Filters and can are fully serviceable​
  • Mishimoto Lifetime Warranty​
  • Direct fit for 2021+ Ford Bronco with 2.7L EcoBoost​
  • Sturdy 2.5mm-thick steel brackets withstand rough roads and off-road abuse​
  • Helps prevent fuel dilution and preserve its octane rating​
  • Catch can captures blow-by, preventing it from fouling the engine oil​
  • Includes molded hoses specifically designed for the 2.7L EcoBoost PCV system​
  • Internal components can be easily cleaned and reused for a lifetime of service​
Ford Bronco Mishimoto Baffled Catch Cans NOW AVAILABLE  |  Lethal Performance NT6_7152-Edit
Check it out below!
Mishimoto Baffled Oil Catch Can Kit (2021+ Ford Bronco 2.7L) - MMBCC-BR27-21P
Do they work? YES
This was collected out of the 2.3L System in just 1000 miles...
Ford Bronco Mishimoto Baffled Catch Cans NOW AVAILABLE  |  Lethal Performance NLT_0236-scaled
And this out of the 2.7L System in 1000 miles as well...
Ford Bronco Mishimoto Baffled Catch Cans NOW AVAILABLE  |  Lethal Performance NLT_9588
As always, if you have any questions or concerns, feel free to reach out to any one of us here at Lethal Performance at 561-753-8105 or by email at [email protected] .
Joe Rocchio / [email protected]
877-2-LETHAL | lethalperformance.com
Ford Bronco Mishimoto Baffled Catch Cans NOW AVAILABLE  |  Lethal Performance MMBCC-BR23-21P_Installed_2
Ford Bronco Mishimoto Baffled Catch Cans NOW AVAILABLE  |  Lethal Performance mmbcc-br27-21_install3
