Miscut Removable Roof Panel
nwGTS
Nate
Chicago, IL
Here's a new one.
My passenger side removable roof panel was cut with a curve on the leading outside edge.
The rearward edge curves up exposing the insulation which leaks and was how I discovered this anomaly.
Warranty replacement but no ETA on a new part.
Pics below plus one of the driver's side to show what it should look like.
Ford Bronco Miscut Removable Roof Panel IMG_4730
Ford Bronco Miscut Removable Roof Panel IMG_4727
Ford Bronco Miscut Removable Roof Panel IMG_4728
JT58Bronc
JT
Fl
Wow that sucks- hopefully you get a new one soon. What are you doing int he meantime to prevent leaks?
I took the panels off in mine once and sliced my finger pretty deep. I did not need stitches but it still bled and needed a band aid for a few days. So mine has sharp edges that probably need to be sanded/filed. I'll wear gloves next time I remove them and file those edges down.
SasquatchMansquatch
4 door basquatch
that sucks. Did it cause any water damage that they need to warranty as well?
nwGTS
nwGTS
Nate
Chicago, IL
Not yet. Haven't driven in rain or snow. Just washed the top that the dealer missed in prep. I poured water that flowed over the door. Some went inside.
nwGTS
nwGTS
Nate
Chicago, IL
Update: Took it in yesterday after waiting a month for an appt time. Service tech took one look and agreed it needed to be replaced. Warranty covered it. New panel should arrive next week. Hoping the color matches well.
