Mike levine confirms that winch will block camera view
XirallicBolts
Xira
Midwest, USA
2016 Flex EcoBoost, 2022 Silverado LT
Is there some reason why they can have a nice one incorporated into the bumper? I am new to offroading and just assuming based on others I have seen that it can be done.
I'm actually dealing with the logistics of positioning a camera right now. At the very least, you need to be able to see the bumper itself. I've been trying to add a front camera to my Flex and the best view is mounting the camera as high as possible, aimed as far downward as you can.
Even the position I have mine right now is too low and judging distance is impossible.
After work, I'm going to finally try cutting into that $400 grille to get a higher view.
Specifically with the Bronco, they *could* aim the camera higher, at the expense of depth perception.
Ford Bronco Mike levine confirms that winch will block camera view IMAG0403
Ford Bronco Mike levine confirms that winch will block camera view IMAG0404
DUSTYcazOREGON
Craig
Seems like an easy fix....move the grill mounted camera to the left of the "B" BRONCO instead of in the center.
rgwinn
Rod
Salem, OR
2001 Harley Road King
Not sure why you couldn’t just move the camera up?
Ford Bronco Mike levine confirms that winch will block camera view 6AD01814-614D-40A6-83D7-F8BCBE88CF72
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
What’s the use of this camera? Is it for off-road?
if it’s for day to day use, I’ve driven for 31 years without one and have never bumped anything with the front bumper. It’s not that difficult.
OKAY, DAD.
LandCruiser
Bocephias
CA
When you are driving up a hill you’re looking at the sky and the hood, so this would be great for helping you find the perfect line without the need of a spotter, or at least to make his (or her) job easier.
BroncBro
2019 Tacoma 4x4
Ford Bronco Mike levine confirms that winch will block camera view B964F3D0-664C-47F9-8E4D-63355A6A3EFD
BroncBro
2019 Tacoma 4x4
What do you do then about some hypothetical future accessory that goes higher on the grill?
So you're proposing a factory installed movable camera
That sounds like an engineering nightmare and I am on Mike's side
If your trying to put the camera in a place to be clear of all hypotheticals, then you would hypothetically have to have a movable camera.....
TNcoupe
Decatur,TN
2022 Badlands, 2023 BD, 1969 F100, 1955 T Bird
I thought that giant hole you look out of with glass in it was for forward view but maybe we're just old.
BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
Honestly, I would have consulted with warn about adding a camera point to the control box. Add a second set of leads, unplug the grill location and hook up the winch control box location. Small cameras are pretty cheap these days.
But what do I know.
