MIC Hardtop Removal Solo?
RedHotFuzz
2022 Bronco Black Diamond 4D
Wear gloves when you try to remove the middle panel by yourself. One side is like a razor blade. I learned the hard way. Had to get stitches when I was trying to readjust my grip after I pulled it off.
I cut my middle finger, pretty good, on the edge of the front/right MIC panel
The design/engineering of this hardtop continues to impress.
Luterdan
Dan
Jacksonville
GMC Arcadia, VW Tiguan, Polaris Slingshot
Can it be sanded or something to remove the sharp edges??
PatientlyWaiting
Brent
Marietta GA
MY22 Wildtrak
It's possible. I'll check that out next time I take it off. It seems like that would be something Webasto would do before delivering to Ford.
VictoryLights
Pittsburgh
2018 Honda Pilot
I hooked up a winch to my garage ceiling. Cost around $200 with parts on Amazon.
How long are the yellow straps around the hardtop? I would like to do the same.
cmcbronco
Illinois
2012 f-150 FX4
watch youtube videos of removing the wrangler hardtop, then mimic that set-up.
What I did was found a cheap hoist on amazon, bought a couple 10'x2" lifting straps. Mounted the hoist in the attic.
Edit for picture
Its crooked b/c I hit it with my head prior to taking this pic
Same here and it works great.
Ford Bronco MIC Hardtop Removal Solo? B3676174-B047-4B48-8CB2-FD4E471DE603
kbBronco
Kyle
Carrollton, TX
2021 Ford Bronco, 2019 Honda Rebel 300
VictoryLights
Pittsburgh
2018 Honda Pilot
Edit for picture
Is this a four door hardtop? Are the 10 foot straps a good length?
Blaven
Pennsylvania
2 inches x 10 feet. I have to try something else to keep it level since it wants to lean towards the glass end a bit. Taking it off isn't bad. But putting it back on needs 2 people to line the tabs up.
FstFrd00
www.gunsmithingtx.com
2021 BD Sasquatch
Same here. I initially had to add another ratchet strap to reduce the lean, but re-adjust your 10x2 straps and it'll sit level(ish) without the need for a ratchet strap.
VictoryLights
Pittsburgh
2018 Honda Pilot
yes and 10' straps work; 6' would've been better IMO.
Okay, they sell 6.5 foot straps. I measured the back piece as about 3 feet, so I was worried whether they would be long enough
Edit for picture
For this to work well, does the hoist need to be perfectly centered above the rear piece of the hardtop? It seems like the bronco could be pulled in a little different every time and lining everything up perfectly during the install seems tricky.
Luterdan
Dan
Jacksonville
That's why I'm actually thinking about the roller type, I can remove it in the driveway, or in the garage, and I think it's easier to control replacing it than dropping it from the ceiling hoping that they all lineup. The issue is the roller ones aren't cheap (esp since we need extension arms because of the height)>
