Method Wheel Group Buy
RealTruck
Lux Sponsor (Level 2)
Amber C.
Ocala, FL
N/A
We recently partnered with Method Race Wheels and worked diligently to bring this opportunity to fruition. As a result, I’m excited to state that from today, until August 29th, we will be offering forum discounts across the entire line of Method Wheels! See details below.
Let’s talk a little about Method. They consider themselves on having, “…The most complete line-up of off-road race wheels for trucks, buggies, rock crawlers, short course, rally, and UTV’s, as well as street wheels for truck, Jeep, and SUV applications. We pride ourselves on providing these products to our customers with fast and friendly service that you can count on. Look for our banners, listen to our name, and watch our products in action. Method Race Wheels…Lighter. Stronger. Faster.”
What’s unique about Method compared to several other brands on the market are their BeadGrip wheels. What is BeadGrip? Well, Method describes it as, “… the bridge between a conventional street wheel and a beadlock, which is often not legal for highway use. Reducing air pressure in the tire increases traction and ride quality while on the trail. The ability to safely run lower pressures without having to worry about the tire de-beading — along with staying highway legal — will undoubtedly be a bonus to off-road enthusiasts.” Essentially, this works through, “Bead Grip grooves, found on both the inner and outer bead seat, engage the tire bead for a stronger hold under extreme side load and lower air pressures. The wheel’s 'safety hump' also gets a more aggressive profile which further stabilizes the tire bead in the seat.” Check out the following video for some more info:
Once again, we’re excited to be able to offer Method Wheels at some awesome discounts for everyone. As per usual, due existing policies, we’re unable to post the discount amounts publicly but shoot us a PM or email [email protected] and we will be happy to provide pricing. We will also need the requested size and offset (if there is a choice) of the wheel you’re interested in.
One thing to note, Method inventory has improved substantially over the last 24 months, however as with most wheels, there will be items not available. If the part number you’re interested in is out of stock, we will provide an estimated time of arrival. If you choose to wait, we will honor the forum price when they’re in. We can also provide alternative options that will still fit the look and function of your ride.
If you have any questions, don’t hesitate to comment or reach out. We’re here to help!
old goat
Raul
Collin Co. Texas
Chevy Colorado
you took to long to come up with this . I already filled the need for other wheels 2 weeks ago
thanks anyway , hope others can take advantage
Shawn_1121
Shawn
Hudson, NH
22 Bronco OBX A51
pm'd
stingfish
florida
bronco 2 door obx
@RealTruck , hey Alex, the Method 703's were all delivered last week. FAST! many thanks.
quick question, the Bronco hub bore is 93.1 and the Method 703's are 106.2. Will you confirm the following hub ring will work for me?
Some Hub Ring descriptions say it has to be exact but the set I found has a OD of 106 (106.1). Will this work with Method 703's OD 106.2?
I found these - WHEEL CONNECT Hub Centric Rings, Set of 4, Aluminium Alloy Hubrings, O.D:106 (106.1) - I.D 93.1mm
OR... do I need to keep looking for a set that is 106.2?
OR OR OR... does RealTruck have 106.2 OD to 93.1 ID rings? I didn't see any in your site's search.
Many thanks.
PS, I'll post a write up once the tires and wheels are mounted up.
RealTruck
RealTruck
Amber C.
Ocala, FL
N/A
Many thanks.
They dont have to be EXACT as a millimeter or two wont cause an issue BUT since Method wheels are based off of being lug centric vs hub centric you wont necessarily need the adapter
