Mesh top for front row only?
JTopsUSA
www.broncosunshades.com
Ram 1500 diesel,
Our front only sunshade prototype is for the 2 door. The 4 door front only we will work on but don’t have high hopes it will perform to our standards.
The sun rider version we have also worked on but it will be a while. As I said previously there are so many configurations we have to see what makes sense to work on.
Things can change and that’s why we make prototypes.
JTopsUSA
Ram 1500 diesel,
Thank you, Nicole. @JTopsUSA Does your support staff know that you have a prototype in the works like you mentioned?
Ok hold on everyone! This is a reply referring to our Jeep Wrangler JL products. We are not making a product that works with the sun rider for the Jeep!
Nym1178
Nicole
Maryland
Mike,
I’d be willing to pay for a prototype and be a tester to provide feedback. For a front only Bimini the rear anchor point can be the same spot the sun rider attaches to in the second row panel. I’d provide pictures but my bronco is currently at the dealership for an A pillar leak repair.
Thanks,
Nicole
JTopsUSA
Ram 1500 diesel,
Mike,
Thanks,
Nicole
Pics would help! We have been evaluating how we want to approach the solution. It's a slow process because we are so busy with summer orders.
Thanks for the offer!
Nym1178
Nicole
Maryland
Should get it back tomorrow and will send pictures.
Nym1178
Nicole
Maryland
Here are some of the photos. I’ll send more later today.
Ford Bronco Mesh top for front row only? 4633F8D1-319E-4271-BBD4-94875484DD7C
Ford Bronco Mesh top for front row only? CA84986F-44DC-4D95-B525-7396D5657273
Ford Bronco Mesh top for front row only? 6F7AF96C-926C-415F-A13D-29CF211E08CA
Ford Bronco Mesh top for front row only? 337DDFAB-101F-4D92-B049-5E3E281A11FB
Ford Bronco Mesh top for front row only? 1611C39C-8529-4F46-B5A9-331835C78508
Ford Bronco Mesh top for front row only? 1450BD72-A302-4BCD-8910-E626A65A908F
Ford Bronco Mesh top for front row only? EB6D407A-BABD-43F7-9F24-FD70449A2FBA
Ford Bronco Mesh top for front row only? F4EE99D5-DDB9-4947-B8A7-99641DCD70ED
Ford Bronco Mesh top for front row only? 0C30680B-5D1E-4C20-AC6E-2CDF2D0C07EC
Ford Bronco Mesh top for front row only? 43B01B4C-F5C2-4387-A19C-0719624363CB
Ford Bronco Mesh top for front row only? 47CCE55B-3CA8-4179-ACA3-F875B5FC76DD
Ford Bronco Mesh top for front row only? C014CE1D-8C49-4D23-8DF6-E9C4D6D8982C
Ford Bronco Mesh top for front row only? 0F54123C-7990-49A6-B95C-DA8C64245D35
Ford Bronco Mesh top for front row only? FFAE15DE-267C-4558-8576-EA48D7E7AAE4
Ford Bronco Mesh top for front row only? 6838C588-A208-44A1-8C78-E09B8CBC6B05
Nym1178
Nicole
Maryland
Mike,
So any thoughts on my offer to be a test subject for a front row only Bimini mesh on a 4-door Bronco?
You should easily be able to secure the rear part of a Bimini to the rear part of the Sunrider top where it connects to the second removable panel. The rest can be secured how you’ve engineered the solution for the full Bimini mesh in the Bronco leaving the ability to still open and close the top.
Ltjb8
Jill
Pittsfield Twp, OH
www.instagram.com
‘22 Bronco Wildtrak
I think they are typically referring to them as “bikinis” that only cover the front seats… I’ve searched everywhere for one. I want one that you don’t leave on with the hard top. I had a Spiderweb Shade for my Jeep which I might dig out of the basement and see how close it fits. 🤣 I’m going to order one of those cheap full size biminis on Amazon while they are on the Prime Day sale for $40 and see if I can modify it to work… 🤞🏻
Here is Mike’s response to me when Jtops did their preorder in May:
Ford Bronco Mesh top for front row only? E2FEB9E8-A1D3-4313-9F22-B2C7134DC122
Nym1178
Nicole
Maryland
So just bought and installed the Bestop mesh access bimini. It definitely works great. Had the Sunrider open the entire week and seats weren’t on fire and I had enough shade. Not flappy even when driving at over 70. Really nice addition. Some slight issues since it wasn’t designed to work with the Sunrider.
- the front magnet does not have perfect contact on the flat metal because it rests on the rounded bolt head.
- It needs two more magnets where the front hooks are to help keep the flap down and connnected to the metal surface.
- The middle roof panel latches, prevents the mesh top from remaining straight and taunt in only that spot around the latch but otherwise great.
I’m looking to add some magnets to keep the front flap down to cover the front gap the other bimini mesh tops have. I would recommend that if Bestop just provides the mesh access Bimini top that stops at the metal bracket of the access bimini with some additional rear support straps, that it would make this a perfect accessory with the Sunrider. Should be pretty easy of a modification but I’m not willing to cut the $270 new top in half right to make that mod myself.
Ford Bronco Mesh top for front row only? E852C2F5-2FD7-4DAB-9D04-913C140113F3
Ford Bronco Mesh top for front row only? C977CD68-B00B-42CC-8A40-C6577FD39FF4
Ford Bronco Mesh top for front row only? 586F658C-4E08-49DC-9C18-9B9A020DDD7E
Ford Bronco Mesh top for front row only? C2350D28-4E99-45B4-B078-1BBB2EE33C21
Ford Bronco Mesh top for front row only? B44DB494-CFD7-47CF-9830-9E042E82C7D1
Ford Bronco Mesh top for front row only? 06F00487-DF76-4A0D-A13B-1949C9EFF2F1
Ford Bronco Mesh top for front row only? 84C335D6-81D8-46E2-BC04-17A868520416
Ford Bronco Mesh top for front row only? CD730CB1-A3CD-4AF7-8523-396B12A1A6E0
Ford Bronco Mesh top for front row only? ACA9CB89-520A-4795-8CE9-07A2186AE7CD
