- Mitch
- Apr 7, 2021
- 91
- 291
- 998
- St. Louis, MO
- Website
- www.pandamotorworks.com
- 2021 Ford Bronco, 2014 Fiesta ST
- Outer Banks
If you are looking to turn up the volume on your 2.7L Bronco and not break the bank, you need to check out the brand new MBRP Cat-back exhaust! With 3 different options, there is a system for every taste and budget! These exhausts feature 3" mandrel bent tubing that utilize the factory hanger positions and 4" OD dual wall tips! They also boast a 35% increase in flow over the factory exhaust. These exhausts are also designed with off-roading in mind with and feature a high placement muffler for maximum ground clearance.
If you are interested in pre-ordering one of these systems, we will also include a free Panda Motorworks T-Shirt with your purchase! The link for the t-shirt will be in the product description! Simply choose your size, and add to cart and the discount will be reflected at checkout!
Click here to pre-order: https://www.pandamotorworks.com/search?type=article,page,product&q=mbrp*+bronco*
Polished Tips: T304 or Aluminized Steel
If you like your exhaust to stand out, then we recommend one of the polished tipped cat-backs! You have the choice of durable T304 Stainless Steel backed by a lifetime warranty or the more affordable Aluminized Steel backed by a 3-year warranty! Both options have identical specifications outside of the material they are made with.
Armor Black
If you are looking for something a little more subtle, then you need to check out the MBRP Armor Black cat-back! Since this option is made of Aluminized Steel, it shares the same 3 year warranty with a separate 1 year warranty on the black coating.
Here are some additional pictures of the exhaust fitted:
Armor Black
