Mabett mud flaps rubbing
Slider
George
Huntsville, Al
2022 F350 Lariot, 2023 Bronco BB, 2021 BroncoSport
I put a set of Mabett's on my 2023 Non Sas Big Bend. I thought I had read that they would fit with 35's as long as you had a lift. I have 2" Zone lift, 35x12.50's Zero offset wheels. Any idea's? Thanks!
Ford Bronco Mabett mud flaps rubbing IMG_1021
Ford Bronco Mabett mud flaps rubbing IMG_1022
rtazz17
Connecticut
2022 Ford bronco big bend
Its your running boards. I have big bend. I had to move running board back 1 inch to fit them. Be advised to do that you must remove and drill new holes in running boards. Actually cut new holes and move the nuts into new holes.
Slider
George
Huntsville, Al
Rtazz, thanks. Makes sense. How big a pain in the arse are they to move back? Did you have to drill new mounting holes for the running boards?
rtazz17
Connecticut
Its a pia. You have to cut new holes. I used a dremel. They are nuts that slip through the cut holes. Once you look under the boards you will see how they are fastened. Took me about two hours to move both sides. Nearly any mudflap you buy will rub the boards. Ford did not account for adding mud flaps that’s evident
Slider
George
Huntsville, Al
I wonder if it would be easier and cleaner to take endcap off the running board and cut it and then put endcap back on?
