Mabett Console Tray Modification
retiredarmymp
Steven
Whitehouse, Texas
2021 Bronco Badlands Sasquatch
I bought the Mabett console tray because the factory tray is too small. The Mabett tray is great because it gives you more storage, the problem is that it’s very difficult to remove it to access the area below the tray. So I modified it to add a Paracord handle making it much easier to remove by simply drilling two holes and then tying knots in the Paracord below the tray.
Ford Bronco Mabett Console Tray Modification A39AD31E-6573-4806-92C4-E1958205A214
Ford Bronco Mabett Console Tray Modification 9EF3C5AD-B159-4168-AADD-8220843A18F7
Broncobren
WT High Pkg MIC Mod Bumper
Great idea!
retiredarmymp
retiredarmymp
Steven
Whitehouse, Texas
Great solution! I was just pinching the center rib to pull it out, not very easy to do if you have items in the tray.
Yes! That was my frustration I knew I had to come up with something different
bronco0311
South Carolina
BTW, I cut out a little notch in the front passenger side that lines up with the groove for charging cords. I put a multiport USB charger in the console and run out a few cords for passengers to charge phones and such. Out of the box, this blocks that path.
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
I noticed that the Mabett tray needs that notch too. I was going to Dremel out the notch. Glad it wasn't just me that noticed that shortcoming. Other than that though, this tray is a big step up over the OEM tray.
GravyTrain
Greg
Oklahoma
LR4, 2020 110
Skateboard grip tape on the center ridge.
