- Banned
- #16
2.7 is a fine motor and more powerful than a stock LS, but it turns my stomach for someone to put a chevy motor in a Ford.
In my experience the 2.7L is a pile, the LS would provide a more linear power band and be much more livable day to day than the 2.7L.2.7 is a fine motor and more powerful than a stock LS, but it turns my stomach for someone to put a chevy motor in a Ford.
I have posted no less than 15 times across these forums my experience with the 2.7L. It may be a good engine for some but my experience left a bad taste in my mouth and I won’t be going back. The 2.3L has well documented Coking issues that shouldn’t be present on any engine in the year 2020. Both engines are terrible choices for an off-road vehicle, turbo power curve and low to the ground, hard to reach alternators are a recipe for disaster.Annnnd that's where you lost my interest. If you want a different engine, just admit it, that's fine. But the 2.7L and 2.3L are good engines
I own and have owned multiple LS based engines including an LS3 now, after some teething issues at the introduction none of the issues you mentioned exist. I have over half a million miles behind LS variants and my experience has been near flawless, one truck broke 2 exhaust manifold bolts is the scope of issues over that time.Umm, have you never heard of the oil ring issues causing blow by, oil consumption and valve build up on the LS's?
Man, you may have in fact gotten a bad engine cause I can tell you aren't happy. Most haven't had your experience at all. The 2.7 will walk all over an LS. My big hang up is you should never ever put a chevy engine in a Ford. EVER!
The LS weighs less than the Coyote, and the Coyote weighs less than the 2.7L, so if anything swapping to a V8 would make the Bronco a more nimble lightweight truck. I think it’s pretty clear your just a fan of small engines.The issues are well documented through many many years. People have even invented special oil just to circumvent the problem on this motor. This much oil consumption will cause tons of carbon build up and coking type scenereos. Catch cans are easy to install and the 2.7 has shown to be a great motor. The problem is you just want a V8 and are venting. The reality is the only benefit is sound. The 2.7 will eat a streatable LS's lunch. An LS will make what will be a beautifully handling 4x4 into a wallowing, nose heavy turd. Would be cool to see you do a V8 swap for the heck of it, but it would have to be a Coyote.
https://gmauthority.com/blog/2019/12/class-action-lawsuit-claims-gm-5-3l-v8-engines-burn-oil/amp/
Isn’t that an irrelevant point? There are two sides to every story. Would you have said the same thing about the redcoats in the revolutionary war?You realize the same way you're defending the LS is the same way people defend the 2.3L/2.7L, right?
LS is significantly heavier than the 2.7 or Coyote, unless you run the aluminum car motor, which would go against you theory of linear power band, big torque with the high rev cam and valve train setup. I like small motors when they have outputs like the Ecoboost's. I also like V8's, but in the right application.The LS weighs less than the Coyote, and the Coyote weighs less than the 2.7L, so if anything swapping to a V8 would make the Bronco a more nimble lightweight truck. I think it’s pretty clear your just a fan of small engines.
The DoD AFM engines you linked to is specific to only that series of engines, the LS3, LQ4, LQ9, LS2, LM7, LM4 and vast majority of vehicles produced with these engines did not receive DoD AFM. Additionally most owners that did purchase that series disabled the feature and never had a hint of trouble.
I’ll stand by the LS engines, as I said, their reliability and versatility is unrivaled.
There is very little reason to prefer the small displacement engine over the more reasonably sized V8. In the real world your going to be getting better fuel economy, have better power throughout the rev range, and have better long term reliability with the V8. Doubly so for an engine going into an off-road vehicle.
https://www.enginelabs.com/engine-t...s-coyote-budget-shootout-coyote-dyno-results/LS is significantly heavier than the 2.7 or Coyote, unless you run the aluminum car motor, which would go against you theory of linear power band, big torque with the high rev cam and valve train setup. I like small motors when they have outputs like the Ecoboost's. I also like V8's, but in the right application.
LS's are good motors, but don't belong in a Ford. Only reason people swap chevy small block in other brands is cost.
If your statement about preferring big motors is true, then manufacturers wouldn't have to resort to small displacement turbo motors across their lineups to meet the stringent National Fuel Economy Standards. R&D for these new technologies is crazy expensive and would not be needed if it weren't for EPA guidelines. You will never get the same cruising economy feeding 8 holes as opposed to 4 or 6 in motors designed for the same class. This is why Chevy has the selective cylinder kill function on their V8's. Diesels are trending the same way. If you statements are true about big motors, why would the manufacturers subject themselves to the R&D costs, bad press and warranty costs of the small diesel blocks with high boost pressures, EGR systems failures and Def problems. Because to meet EPA specs, they go to smaller motors and to win the HP wars, they run them on the edge.
I'm not anti V8 by any stretch of the imagination. I just wanted to clear some misunderstandings up for ya.![]()
