Level kit noise
Mjmcknight0
Clearwater
Jeep Grand Cherokee
I get a “clunking” noise when I turn sharp after they installed my zone level kit. Any ideas?
iamchewby
Chewby
Yeah that's a problem... check the torque on the bolts, top and bottom, if they're tight then have another shop check it out. Either your shocks are moving about or your axles are binding. Both of these scenarios are bad.
Exomodo
Ryan
Marquette, MI
Ranger
Your $60 or $120 puck lift is malfunctioning? Hmmmph...
Mjmcknight0
Clearwater
Jeep Grand Cherokee
Is there one more expensive I should have bought?
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
Definitely take it back and
Plenty of folks on this forum with that leveling kit with no issues like this reported. Suggest taking it back to where it was installed and ask them to check it out. I have very limited experience with "clunking" while turning, however both times it was a ball joint issue. Since they have to disconnect your upper ball joint from the control arm for that spacer lift, I'd start there for checking if it's all torqued up.
iamchewby
Chewby
No, they're perfectly fine when installed correctly. I've run spacer levels on several vehicles, including the Bronco, never had a problem. Something went wrong on installation.
