Let's get real on maintenance
Rick Astley
Up Doug's ass
d
You didn't really answer what I was looking for
Does removing the wheel give you better access than turning the wheels to the side? It's not hard to pull a wheel and if it gives you better access maybe some would prefer to pull the wheel even if they don't have to because it makes the job easier
If a dealer was servicing the truck on a lift do they remove the wheel? Even if just to rotate tires at the same time
Just breathe a bit dude, the trucks got a minor serviceability issue, it's not a fatal flaw
Breathing fine. I'm 6'1", 250 lbs with wide shoulders. It's not difficult for me to straddle the wheel (as it's turned hard right) and remove the three little clips to pull back the splash shield, left arm over the side of the wheel, right arm in the well. For oil filter removal I can one-hand the strap wrench with right arm, then lean in for un-screwing.
We don't have turning radius specs for Bronco yet (do we?), but I would assume it is better than Ranger, so there is more room, even with the taller/wider tires. A guess (not having any info on the Bronco wheel well, and assuming the exact same filter arrangement), is that Bronco would be easier. Especially for the drain plug as Ranger has less ground clearance.
Seems to be a non-starter issue in my mind. Although personally I think that Ford will re-locate the filter location for Bronco, even if only slightly by way of adapter plate.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
i guess i have to learn about inches and all the fractions that make up in an inch. always had european cars. so millimetres are very nice to work with. no 5/16ths BS to deal with. it's a 8mm, 9mm, 10mm. all nice round numbers to work with. they're double digits even. no fractions to remember like some made up measurement.
Ford Bronco Let's get real on maintenance nm2dvyp3js541
2Jeeps&PatriotX1
Denver, CO
I dont know about the 2.7, but on my 3.5 they placed the oil drain plug in the wrong spot. If its the same, and you've never experienced it, its quite something your first time to see how far it shoots out the passenger side of the vehicle. Think I measured close to 5’ lol. After that, I was forced to watch a video even though Ive done 50+ oil changes on my various vehicles over the years.
Regarding brake pads, never had a challenge changing even on import vehicles. Takes me longer to get out the jack, stands, tools, raised in the air and tires removed than to swap the brakes out.
aabsalon
Alan
Sacramento
Toyota Tacoma
toystwo
KY
Avalanche, Tracker, S-10, 911, GTI, Volt, 528i
Good news for you, all auto manufacturers use metric fasteners.
Karl_in_Chicago
Karl
Chicago
STOP REPEATING THIS INCORRECT INFORMATION!!!!!
If you do not personally KNOW something, VERIFY your "opinion" before spouting it. By the time I could even give the correct information in post 21, somebody already spouts the INCORRECT information from some damn article that came out before Rangers were delivered that had to be corrected or redacted.....
YOU ARE INCORRECT ON THIS MATTER. YOU DO NOT HAVE TO REMOVE THE WHEEL TO ACCESS RANGER OIL FILTER.
But you still have to dismount/remount/balance the tire, right? :ROFLMAO:
Jp215
James
Pennsylvania
2015 F150
I don’t know what they are going to do on the bronco but on my f150 with the 2.7 and all the 2.7 I’ve seen in the shop have plastic drain plugs.
Jp215
James
Pennsylvania
2015 F150
I’m my 16+ years as an auto tech. I’ve used my standard tools maybe 10 times. And when I do it’s usually assembling equipment or the rare occasion a 70s mustang comes in. That happened 1 time
Broncocito
B
NM
2021 Tacoma TRD PRO Manual
I'd like to be a wise ass like everyone else, but decided not to be for one.
1. If similar to F150 it doesn't look too bad, similar to Ranger more of a pain but doable.
2. Most likely
3. Brake pads I've always felt are pretty simple. Sure you will need metric, because you know... Europeans ?
4. In the last 20 years ever known a serpentine belt to be all that simple?
5. Unless it's a Mustang, they never seem to be.
6. Can't see why it wouldn't be. Except for the post above mine that said it is on an Escape.
And if I may add to these questions (before I A Google it). Does this little V6 have a timing belt? or better yet a timing chain? Hoping for a chain!!! And off to Google I go.
Edit: Seems from what I'm seeing online.. it's a chain.... thank god!!!!
Amen on the chain!
WRF3MD
Will
Maryland
Ford F150/Ranger
A 1-1/4" hole saw should solve that problem haha
