I left mine off. Seemed to get more juice out of the amp with it off. It does render the adjustments unusable, but I don't mind at all as I don't really need/ use them.Successful DSP Setup. I noticed you suggest Fader dip switch on OFF. Any particular reason? I followed your steps and I’m extremely happy with the results. Do you turn Fader dip switch on after setup? Or leave it off? Does that render the Fader adjustments unusable from the touch screen?
One thing to check, is to see that your reverse parking aid is working. A couple of weeks ago mine started beeping very faintly, it's very hard to hear. Not sure if an over-the-air update might fix this issue or what caused it to being with.
