Kicker Hideaway questions/issues
Badassbronco
Georgia
I just had one installed. I noticed that it seems like some frequencies it doesn’t play and some it does. I adjusted the crossover but it didn’t help. It’s like it will play a 60hz sound and then play a 65hz sound but it wouldn’t come out of the sub if that makes sense.
Also what sendings are y’all using for the hideaway? I have it on Hi input level, 0 phase, Gain 80%, bass boost 50%, and the remote at 75%.
I actually sounds like it has more bass when I switch it on low level even though it is connected through the kickpanel and not RCA.
The directions also say when setting up puT EQ flat. Can I change it back now??
Rus-T
Rusty
FL
Ford Bronco Black Diamond
Do you know which speakers were tapped into for the input? You definitely have to use the front kick panels. The rears have bass blockers/frequency blockers so the sub will not sound right. I originally used the rears for input and knew there was something wrong. I switched to the fronts for input and it was a night and day difference.
