Just installed front mud flaps (pics)
KANE COUNTY ILLINOIS
SAL
GMC YUKON
I just read a previous posting, that yours is a two-door, which probably doesn't have the 4-door problem!
SAL
GMC YUKON
gordonl
Gordon
Richmond, VA
BMW 328ix wagon!
I bought some of these, and got them in the mail a week ago. I am hesitating because the instructions definitely say to drill the wheel arch. I am struggling to want to do that.
Smaller issue, I have rock rails and definitely will need to cut a hole for the rails. Lesser issue, but a pain.
Amcole1984
Amcole1984
Amber
2021 2 door Bronco Big Bend
I have the 2 door. I did not have to drill anything. The 2 holes you need are already there. Not sure about a 4 door.
JaxGtc
Did you remove the crash bars? I have a 4 door and as mentioned, they are 3/4 inch too long. I just haven't gotten up the nerve to cut them down and then work on the notches.
I swear those rails are plastic. I am going to try a heated box blade on the notches instead of a dremmel tool when I do it. Miter saw on the end and angle cuts.
Ford Bronco Just installed front mud flaps (pics) Step 4
Ford Bronco Just installed front mud flaps (pics) Step 8
Amcole1984
Amcole1984
Amber
Yeah, had the crash bars removed when I added the lift and 35s.
BigFootie
Wisconsin
Looks great. So does your your Bronco. The tires look great on those wheels.
SAL
GMC YUKON
Nope. It comes with heavy duty clips that attach it to the fender flares without having to drill.
Are you still able to remove the wheel flares by removing the clips?
SAL
GMC YUKON
Yes. You are able to pop them off.
Thanks for the info! The instructions included with the mud flaps are terrible! Do you put the mud flaps behind the wheel liner? Are you able to take a photo of the installed front mud flap at some point? So I can get an idea of how it's installed? So no drilling? I see in the instructions that the tools needed includes a drill bit, or am I thinking of my rear mud flaps?
Amcole1984
Amcole1984
Amber
On top of the wheel liner. I have a 2 door non sas Bronco (added lift and tires later) and only installed the front flaps. Not sure about rear flaps, or differences if you are installing on a sasquatch. There are 2 pre drilled holes you use and 2 fender flare clips.
Ford Bronco Just installed front mud flaps (pics) Screenshot_20220204-235216
Ford Bronco Just installed front mud flaps (pics) 20220204_235143
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
I was going to forego mud flaps - figured my 'soon to be installed' Rock Slide Engineering slider steps would suffice, but seeing that they still leave a pretty big gap at the front and driving in the foot of snow we just got I don't think I'm going to have a choice.
The snow/slush was just flying up the side of the Bronco - my door handles were caked, as was the front of the rear fender so much that it overlapped the back door by 4". I can only imagine that my sliders will be buried deep in slush if I do not get something...
Check out my mod.
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
I’ve been in touch w Rokblokz and (as usual at this stage in the game) was told Bronco flaps are in development.
