JKS Max Tire Clearance Kit Needed?
Slick85
Richard
Austin, TX
So I have a 4 door big bend with a 4" Zone lift and 37" Wildpeaks and while it's fine most of the time, I can feel the occasional rub when I do a U turn or when leaving a big drop from a driveway. Would the JKS kit help with this or no?
Felix808
SRV CA
Have you identified what it is rubbing on? If it is rubbing on the skid plate it won't help with your issue. It will make the front end look at lot cleaner though 🤠
1st 75th ranger
jeffrey
nj
maybe or just a touch trimming ...isolate rub then decide
Slick85
Slick85
Richard
Austin, TX
It will? Do you have a before/after photo with the kit installed?
Felix808
SRV CA
I don't, but picture all of this boat anchor material surrounded in yellow no longer there 🤠
Ford Bronco JKS Max Tire Clearance Kit Needed? 16_2
