JCR vs M2M for lower molle panel?
KyleV
Kyle
2022 bronco black diamond sas
I have narrowed it down to 2 brands for my molle.
Any experience with jcr or m2m?
I'm leaning jcr because it looks a little tighter to the plastic than m2m, but I don't know if that's good or bad.
I have the M2M installed - easy install, works great, and easy to switch between soft top and hard top.
I can probably get a better pic if you would like one - this one doesn’t show much on the panels.
Ford Bronco JCR vs M2M for lower molle panel? IMG_1862
braddavis2017
Bradley
Breinigsville, PA
Ford Bronco
Commenting as I would like to see pictures of someone who has installed the JCR Lower Molle Panel on a Hard Top Bronco without the rear window Molles.
All aftermarket sites have it attached with the window Molle bracket but it looks like there are three bracket options total (window molle, hard top, or soft top).
Curious to see the final fit and finish with the hardtop bracket for JCR.
