Jack options?
Dmorty217
Derek
Venice FL
Camery
What’s everyone using for a jack solution? I measured today and my frame is 16.5” off the ground which limits most jacks since they only lift to 18-18.25”
Dmorty217
Dmorty217
Derek
Venice FL
Camery
Felix808
SRV CA
My Quick Jack BL-5000 SLX & a floor jack w/ a block that lifts about 24" when just doing a side or 2.
goatman2
Richard
Bakersfield
gandgautorepair.com
F450, Jeep XJ, Porsche 911, 2dr Badlands
A bottle jack under the axle. Don't bother lifting from the bumper or frame. Haven't tried the factory jack, but it looks pretty capable.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
At home a 4 ton Pittsburg, it lifts to around 22" iirc. Still debating what I want to get for trail use but the scissor jack has gotten me by.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Front jacking point is indicated by an arrow-shaped mark on the frame. Rear jacking point is on the rear axle tube.
Ford Bronco Jack options? 470C5659-29E3-408A-B7DB-B077D372834E
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
Have a 48” hi-lift for off road. Stock should work for street.
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Safe Jack bottle jack. The General (offroad) package. I have everything fit into the cargo storage space
I second the Safe Jack.
MadMan4BamaNATL
Ray
Atlanta
I’m a big believer in a bottle jack for most applications With a decent, but cheap stand and maybe with a small tarp under it all in muddy conditions.
If you don’t have a winch, a Hi-Lift on a stand can lift you out of almost anything besides deep mud and water bogging. When lifting off of an obstacle (Rocks, etc) this jack can be dangerous, so practice and properly knowing how to use is critical for you and your rig.
Storing a Hi-Lift sort of sucks unless you’ve planned on it already and have a solution.
iamcris
Cristian
Lakewood, WA
21 Bronco Badlands
have the same, I bought the blue one which color did you get?
Dmorty217
Dmorty217
Derek
Venice FL
Camery
I am buying a winch for when I get stuck off road, this is more for use in my driveway especially adjusting my coil overs. Rotating tires and oil changes ect will be done by the dealership since I have already paid for all of that
Tricky Dick
Dick
PNW
AMTRV
Oliver
United States of America
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
So, what is your lifting points to lift a Bronco with a Hi-lift jack? Do you have custom steel bumpers?
MadMan4BamaNATL
Ray
Atlanta
Don’t have my Bronco yet, that’s for my old Disco, but you should be able to use a high lift on any 4x4. I imagine that the regular lift points would work for the Bronco, not sure about the rock rails if you even have them. Not sure about the bumper either, but you should be able to reach the frame mounts when doing a recovery.
