Is clutch pedal spring assisted?
AZ_Liberty
2007 Expedition
Does the Bronco have a stupid "assist spring" on the clutch pedal like the newer 'Stangs?
If so, has anyone removed it, or checked to see if the Steeda spring fits?
Just planning ahead now that I finally have a VIN.
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Never owned a manual stang, so cant comment
curious though
AZ_Liberty
AZ_Liberty
2007 Expedition
Hmmmn....
Has anyone removed it yet to see what happens?
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Bump
DaveInSA
Seguin, Texas
2025 F150 Lightning Flash
The clutch is 'fly by wire' like everything else (except the hood release). You're not physically controlling it.. So I wonder if removing the spring just kinda makes it flop around?
Aman
Aman
Northern NJ
Hmmm, sure doesn't feel like a clutch-by-wire system. Is there any documentation I can reference to figure out how this works?
I'm pretty sure the 7MT is still using standard linkages, so would be surprised if it the clutch is CBW. 🤷‍♂️
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
The image posted above looks to be a hydraulic clutch. So pushing the clutch is really pressurizing a hydraulic line that moves a piston near the clutch to actuate it.
With regards to disconnecting the return spring, that is not a good idea. The spring insures you have full return of the pedal.
AZ_Liberty
AZ_Liberty
2007 Expedition
It's a very common mod on the Mustang. Either to remove it entirely, or replace it with a much lighter 35# spring. The advantage is it gives you a heavier clutch feel, more linear response, and you can feel the engagement point better.
I guess I'll find out "by September"
acarzt
2022 Ford Bronco
I've seen a lot of people do that mod, but never really felt the need to do it myself. I've had 3 manual Mustangs ('08 GT, '13 GT, '19 Bullitt).
I did add a pedal extension on the clutch pedal though since Ford likes to position it further back than it needs to be.
I went Auto with the Bronco so my GF can drive on road trips. (I tried teaching her stick, it didn't take 😂)
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Im single, so I didnt have to worry about a gf
Deleted member 32220
Guest
That is a resistive spring. It is a hydraulic clutch. Your just moving the fluid you don’t feel the pressure plate force… Clutch by wire has never been used in the automotive industry or anywhere else for that matter.
Electric clutch…🤣 It would sound like your electric parking brake every time you pushed it down engine off or on.
tbrow96
Pennsylvania
Truck
Has anyone removed the clutch assist spring? Or replaced it with the Steeda spring?
