Introduction and Top Question
KentuckyBronco
Everglades
Kentucky
2023 Bronco 2018 F-150
Everglades
Hello everyone, thanks for creating an informative place for discussions on Broncos. I was finally able to get the trim level I have wanted for a while and recently purchased a 2023 Everglades with very low miles.
My question is for those of you that have both a hard and soft top. Any significant issues going from one to the other?
Also, any tips on making the transition between tops run smoother and a little quicker? It took me over an hr today to switch From hard top to soft top.
Ford Bronco Introduction and Top Question EC193B47-2CAB-4AF1-8F85-D9A75A901998
Ford Bronco Introduction and Top Question 6B559274-E928-4A26-AAD1-2C83C5BB1F90
The hard top isn’t too bad to take off or put on. Especially if you do a pulley system. It can be done solo (especially with a pulley) but is very easy with two people.
The soft top though - I haven’t found a good way around just having two people and being careful. It’s heavy and awkward, even with two people. I tried solo one time and it’s just too hard to get it around the C pillars without royally messing them up. Might be able to rig some sort of pulley up for it, but it’s a totally different beast than the hard top
Hardware wise - once it’s been done once and all aligned up, it’s just 6 bolts off / 6 bolts on for either top.
The soft top is a big enough pain in the ass that I only swap it on in the Spring and leave it until Winter
