Interior water intrusion questions
Cobra Jet
2018 S550 / 94 Cobra SVT #13
Questions below are more in reference to the 2DB, rather than the 4DB or 4DSport.
What is the Interior resistance to water intrusion with regards to the dash electronics and HVAC system?
Meaning suppose an owner is out and about with no doors and no roof - gets caught in a storm (or encountered large body of water during trail riding). Will electronics be damaged If wet or HVAC be damaged if rainwater goes down the vents?
BroncoFanBoy
Brandon
Az
Nissan
I highly doubt they are recommending or guaranteeing that the whole interior is water proof.
Everyone with a convertible top runs the same risk, IMO
tyrobronco
CC
Central Florida
2021 Bronco,2017 Ford Fusion Energi
Everything has rubber around it in the hopes no water gets into them.
WuNgUn
Ontario Canada
2 door Squatched
Not everything... Steering wheel buttons and dash top buttons only, from what I've seen. Your center stack would not like getting wet!
Toccoa
Isuzu Rodeo Sport
They're advertising this. So, I imagine water intrusion has come up in their engineering discussions.
Ford Bronco Interior water intrusion questions 1595102883907
Garemlin
Delaware
The Wranglers all have some sort of water resistance with all of the electronics. I'm sure the Bronco will as well. What the IP rating is who knows. I wouldn't be too worried about getting caught in the rain for a short time. Or water splashing in. But I don't think I'd be comfortable hosing down the dash or center console.
dmtndan
1991 Silverado, 2014 Malibu
I would imagine everything within the 33” of water fording should be able to take it. Aka, there should not be any water going into the air vents in the console that will be well above 3 ft off the ground.
Chadillac
Chad
Between the Hedges, Georgia
Silverado Z71, Explorer ST, Mustang GT
I’m sure it’s similar to your “waterproof” smartphone. A splash or spray here and there shouldn’t hurt anything. I wouldn’t intentionally spray the dash with a hose though.
Deleted member 3063
Guest
big difference between water resistant and water proof as some smartphone owners can attest.
And I suppose some Jeep owners with remote sway bar disconnects.
