Interior cargo rack
adamruiz2001
SoCal
Ford SVT Lightning
bjpatten
Apple Valley Utah
2022 Bronco
I got one from Trail Hero for $150 but haven't installed it yet.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
that seems HIGH and that top seems to open a lot more than normal? Either way, GOAT Fab! check them out! Great cargo rack, american made!
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
I have been looking at a bunch of these options as I am about to pull the trigger on one myself.
The Havoc one you posted seems to sit very high, blocking most of the view out the back window (even when empty). It also mounts to the top of the inside of the hardtop, so it needs to be removed to in order to remove the hardtop.
The M2M one is a cool idea, but since it folds up it is limited in how big it can be and IMO it’s just too small for my needs.
I want one that doesn’t need to be removed in order to remove the hardtop. That narrows down the list of options, but I feel like each has pros/cons.
American Adventure Labs is adjustable in height (highest amount of adjustability), large cargo size, looks very nice, removable side rails, has accessories made specifically for it, and made from aluminum. However the mounting brackets seem bulky and cover the nutserts on the roll bar, it’s expensive, the additional accessories are expensive and add up as well.
https://americanadventurelab.com/product/ford-bronco-mass-adjustable-height-cargo-shelf/
Goat Fab is adjustable in height, mounting brackets are sleek. However the sides are way to tall, its narrower than others (I think the height of sides plays a factor in this), it’s expensive and the basket only comes in steel.
https://goatfabrication.com/collections/4-door-bronco/products/goat-bronco-4-door-rear-cargo-basket
Rock Hard 4x4 has a nice large cargo size (widest), comes in aluminum or steel, mounting brackets are sleek, does not block rearview when empty and cheaper than first two options (aluminum $400, steel $350). However its main downfall is it has no adjustability.
https://www.rockhard4x4.com/product_p/rh-60940.htm
Hooke Road is the cheapest option ($230) and has the deepest platform. However it has no adjustability, the brackets are extremely bulky
https://www.hookeroad.com/collectio...d-bronco-interior-cargo-basket-storage-b8917s
Ultimately I like the AAL basket the most, the brackets from Goat Fab, and the price from Rock Hard. At this point I am considering getting the Rock Hard and fabricating my own adjustable brackets, unless I am very happy with the height it comes at. Sorry if none of this applies to your needs, but I figured it would give me a reason to write down the pros/cons and hopefully make a decision as I need it for a trip planned mid January.
adamruiz2001
adamruiz2001
SoCal
Ford SVT Lightning
MaximuNashville
Adam
Nashville
‘25 Badlands non SAS
adamruiz2001
adamruiz2001
SoCal
Ford SVT Lightning
Thanks, this is some great information. I would need adjustability and would be nice to have either a half rack or full rack at times.
I appriciate your time on detailing each one, this info will be benaficial to others in the future. Thanks
-Adam
adamruiz2001
adamruiz2001
SoCal
Ford SVT Lightning
I think you are right, one is for hard top only and the other is for either soft top or hard top
IwannaGOfast
Jon
Brea, CA
Yes this one is for the hardtop, however in order to remove the hardtop you will need to uninstall this shelf. That is why I am looking for an option that mounts off of the roll cage, like the 4 above that I linked.
bronco_billy
Indy
Crown Vic
This from HookeRoad;
Ford Bronco Interior cargo rack IMG_2821
Ford Bronco Interior cargo rack IMG_2820
Ford Bronco Interior cargo rack IMG_2819
Ford Bronco Interior cargo rack IMG_2818
Ford Bronco Interior cargo rack IMG_2817
adamruiz2001
adamruiz2001
SoCal
Ford SVT Lightning
IwannaGOfast
Jon
Brea, CA
That is the rack that I linked in my initial post. It’s a great option, especially for the price. The things I did not care for are that first of all the height is not adjustable. Also the mounts cover one of the nutserts in the roll cage, so any other products that utilize those mounts, will most likely not be able to. Also the bracket sticks up past the top of the roll cage as well, further limiting usage. Obviously these are things that are concerns for me, and may not apply to others.
