Instrument cluster display question
The_Axeman
Sean
Montréal, Québec, Canada
2021 Ford Bronco 4dr Badlands 7MT
How do I get to this screen display? I can’t seem to get there. It’s always just a small screen on the right….
Thanks in advance.
Ford Bronco Instrument cluster display question A301AB5D-85BB-4581-AEBE-9B628D276F50
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
Press the back arrow button twice on the steering wheel. It should be at Main Menu.
Choose Off-Road, then Off-Road Status.
Off-Road on the Gauges screen is usually where I keep it. Its only a few clicks up and down to more useful info.
Vtfakie
Robert
2021 Bronco 4dr Wildtrak, Lux, Leather, Tow
Thanks in advance.
Press the hamburger button (three horizontal lines) on right side of steering wheel, choose off-road, then offroad-status. I am not seeing the tire pressure on mine at the moment, but could be because my Bronco isn't running at the moment.
The_Axeman
The_Axeman
Sean
Doesn’t work for me. I put mine in Sand mode as well just to check. It’s one or the other for me. Here’s a pic:
Ford Bronco Instrument cluster display question F6FC14AF-7C51-451E-878A-24DF22E987C2
Vtfakie
Robert
Press the down button, there are other off road display options
The_Axeman
The_Axeman
Sean
nope. Been through them all. The screen always remains small. 🤷🏼‍♂️
HeliPilot
Kenny
CT
2022 2.7L SAS
Select off road display, go to sand mode, maybe it works in other modes as well, then place shifter in neutral, then select 4low. You will get the screen you’re looking for. I didn’t check to see if it also displays with 4high, but your screen shot seems to show that it will work there too.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Reboot your vehicle with a negative battery disco. I reset my vehicle for another reason but then was like whoa that's useful. I think something got hung up in an over the air update as I had the larger image, fordpass notification of update, then the smaller image, rebooted, now big image.
WuNgUn
Ontario Canada
2 door Squatched
Maybe you have to be aired down...
Just went to rock crawl mode, locked everything, sway disconnect...and all I get is this...
Ford Bronco Instrument cluster display question 20211223_110336
AlpineFisher
Seattle
1971 Bronco
Do you mean just disconnect the negative terminal for a minute and reconnect? Is that what you mean by "reboot"? I only have the small screen as well and it's super annoying
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Yes exactly.
OregonMike
Gresham, OR
2010 Fusion, 2021 Bronco
What if you turn off the lane assist?
81arctic
Jon
Granville MA
2021 MT 2.3 Badlands
Yes exactly.
Did you try this? I also would REALLY like to get to that setup. My badlands is stuck with a digital speedo next to the needle, total waste of space, would love to see the off road info plus tachometer like the example. I tried every combination of workarounds in this thread (except negative disco) and still stuck in the same setup you are
Slimpickens
Apopka, FL
FJ Cruiser
This is extremely frustrating! I have the same issue. Just tried the neg battery “solution”, made sure SW was up to date, still no larger 4x4 screen. Tried different GOAT modes, etc. I have advanced 4x4, drove the same model at ford’s bronco drive and that one had it. Didn’t know I was missing it until after I drove theirs and have been unable to get mine to display.
