Installing rough country 40" LED bar
Travis
Everglades
Hi everyone!
So I'm new to bronco and I purchased the 40" LED bar from Rough Country for above the windshield. Has anyone installed that on their bronco? It has a thick cable that doesn't wire into the auxiliary switch. Do I have to cut that wire and pull out the wires inside and then wire it that way? I haven't done much electrical work so I'm not sure if that particular bar will plug into the aux switch or not.
Also, I have a soft top and the LED bar makes the roof rattle like crazy when I'm on the highway. Is that normal? What do you guys do to prevent that?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Hi everyone!
You'll want to run the wire down the windshield (in the little crevis) and then under the a-pillar plastic cover on the outside. DO NOT use the wire ford left you inside as you have to drill a hole AND it's a TINY TINY wire.
Then you can extend it over to your upfitter switch. RC doesn't give you vehicle specific wiring so you're on your own with their setup.
As for the noise, these do the trick: https://www.4x4truckleds.com/led-light-bars/wind-diffusers-accessories/
For a 40" Bar you'll buy the one for 50"/52" bars and just cut it to size.
lordbigoftasty
Travis
Everglades
Thank you!!
